the bushings make sense if you think about it... they act as bumpers that cushion the motor when rolling all the way up or down and avoids breaking the plastic bottom ring gear... another difference between my fiance's car and mine is the access holes in the door to mess with stuff... it seemed the holes and stuff are different and more in the older door... my door had paper under the interior panel and hers was plastic
Windows not rolling up, but you can hear the gear turn?
This is a sticky topic.
after I replaced the nylon bushings in the driver door of my vic twice within 3 months... I said to hell with that and put in bearings. Haven't had a problem since. Did have to replace a plastic gear in the 88 though... put the wrong size bearings in that one. remedied that when I replaced the gear.
7/16 bearings. and IIRC the nuts are 2 stacked 1/4-20? You could definitely use 7/16 rod cut down to half inch lengths. That would definitely work better (I have not the tools for such though... at least not accurately and in quantity). Chamfer the ends to keep it all smooth of course.
Originally posted by Grand Marquis GT View PostFor what, silicone grease?
The stuff sold in the little packets at the parts counter will work just fine, as that is what I used.
something like this... https://www.walmart.com/ip/CRC-Heavy...Wt-Oz/16817419
Cool, thanks
Originally posted by sly View Postsomething like this... https://www.walmart.com/ip/CRC-Heavy...Wt-Oz/16817419
What about the bushings, I think the grease I have used has attacked them.
Bushings? White lithium works a treat. Lucas Red and Tacky also works great.
Cool, thanks Sly.
