My 2004 Mercedes Benz E320 aka The Benz
    Fun. I need to do a blower motor in the Continental but its a real PITA so I've been ignoring it. Last year I drilled a small hole in the fan blade so I could poke an extended tube from an oil can back there. It worked for a while but its getting unhappy again.
    How big of a pita? Dash Removal?
    Make the temporary fix a monthly staple?
      The blower motor is up against the firewall on the inside. Basically I have to peel the dash away from the firewall so I can take the HVAC crap loose to peel it far enough out to clear the motor. Shooting oil in there is a whole lot easier, but this time I'll have to use something that doesn't smell so much. PB Blaster has a scent that lingers.
        Just a tick under 139K
        Had a chirping sound when idling and giving it a tad of gas. Figured I would throw on a tensioner and idler pulley and new belt. Same sound still. lol Idler was screwed anyways super noisy so no loss there. Dug into the sound further and it is the drivers side exhaust. Will look into that when I have the motivation. Not going to lose an engine over it so it can wait.
          I've probably replaced more tensioners than any single item on a car except possibly spark plugs. Never had one completely fail and throw a belt but I dislike chirpy belt noises. I think they use the crappiest bearings available on purpose. I like the ones you can actually rebuild. Press out the junk bearing, press in a better quality one but thats usually only on metal wheels and then only certain types.
            Both the tensioner pulley and the idler appeared to be of the plastic variety on this set up.
              Found my chirping sound. Rotted off exhaust hangers on each side next to the transmission. The little rotted bits were rubbing on the exhaust under load and causing the sound. Exhaust pipe was unaffected.
              Fabbed up new mounts and boogerwelded them into place. Smothered some high heat paint over it and called it good.
              Pics of old:
                Couple days ago it started getting chilly around here so I turned the climate control to warm me up and nothing but cold air came out the whole drive to work.
                Had this problem years back (2015 apparently) as I had already purchased the heater control valve to do this job but at the time it miraculously started working and worked up to date.
                Have to remove the windshield wiper arms, the cowling and then the window wiper mechanism to gain access to the control valve. Four ports on the valve, two quick connects to the heater core, and one more quick connect to either the supply or return and one hose clamp for either supply or return. One electrical connector and the bugger is out.
                Couple videos about it on the web and I think it should not be to big of a hassle to accomplish.
                  Still doesn’t sound like a walk in the park. I am betting you are one of the few Mercedes owners who do their own fixing.
                  My dad did some brake work on a 1972 280SE 4.5. I was about 15 or 16. A completely different animal than yours but I remember parts availability was horrible and it fault him the whole time. It was a nice car though. Fuel injected, four wheel disc, and a factory in dash cassette player (not 8-track).
                    electrically controlled valve with an internal bypass so coolant goes back to the engine when no heat is requested?
                      If you don't do the work yourself the job would cost more than the car is worth! Joking there but I am sure the dealer will take you for all your worth. I don't have the money to get a new Benz every time the lease runs out...
                      Precisely. Electrical motor and some gears to control where the flow goes. During warmer weather I would imagine the core is bypassed completely. Culprit seems to be things seizing up in the works.
                        I'm pretty sure I watched from the side while a friend did this last winter. I don't remember it taking that long, even with all the sarcastic Mercedes remarks from us bystanders. That one was a 4 cyl diesel, so it might it be a bit of squeeze with a V6. Either way you're going to spill coolant everywhere.
                        While MB service prices might be horrendous, those cars aren't exactly rocket science to work on. Especially the E-class as the engine isn't knee deep under the cowl and windshield, like in Beemers.
                        Like with any new-ish car, there's a load of stuff in the way before getting to anything.
                        2005 Volvo V70 Bi-Fuel
                          Nice Benz. There’s a guy in Chicago with a twin to this that pounds the car over potholes. Warped perception something or another.
                            Went well. Not as much coolant as I was expecting. Parked in the backyard which has a slight upwards angle to it. DOnt know if that helped or hurt.
                            Thanks.
                            I checked out a couple of his videos. Pretty cool.
                            Changed the heater valve out today. Went well. No cursing smooth sailing. Heat is back.
                              Though I did not drive the car too much this past winter on the cold days I did it was nice to have heat again in the cabin!
                              Washed the ol'gal up today. Still sitting pretty for having roughly 142k on the clock.
                                Beautiful car! Ballin!!!
