1978 Caprice, the new on-going project! (Yes, I'm still alive!)
should be some warning lights in the segments and a center with nothing in it IIRC, though I don't think it's a full 2 inches to fit a mini tach, but it might be.
1984 Ford Crown Vic LTD, The Murphmobile (RIP) 1985 Ford Crown Vic LTD, The Murph Deuce (SOLD)
I know there's seat belt and brakes, I'd like to say oil pressure, low fuel, battery, engine temp... Not sure about the last one though!
I painted the HVAC bezel today, the wood trim looked way out of place. Gloss black flows 10x better...
Sent from my VS985 4G using Tapatalk
The past few days I've been scraping, painting, painting... And painting the underside of the car. It has a lot of odd rust spots I'm trying to get under control, or at least slow down. I'll post a pic of the back end of the car later, that's where 90% of the work needed done.
I did do a little more painting on the front end though! Unlike the Crown Vics, the headlamp bezels are removable as a seperate piece on my Caprice. Goodbye oxidized chrome, hello gloss black!
I realize not everyone digs the black headlight trim but its worlds better than crappy peeling "chrome" IMO. I fixed the bumpers on my first 2 cars with black paint. Rusty chrome looks horrible.
Black bumpers do look good on the right cars though!
I did get the underside of the trunk finished, it's not perfect and not a permanent fix, but it is 10x better. I did find some rust holes I didn't know I had before though...
I really need to work on updating this as I do things! I pulled all the plugs back in September, no oil on them at all, so I'm quite impressed! I also found that my alternator plug was rigged up to say the least, so I repaired it properly.
I also did a little more rust repair, as I went to replace the trunk seal and discovered a few areas of rust hiding behind it. I also finally got around to scraping, sanding and painting the area behind the license plate. My dash finally got a crack as well, so I tossed a velour cover on it quick to keep it from worsening.
Right before I put it away, which was done Friday evening when it was still 70 degrees, I used an Eagle1 polishing mitt on all of the glass and chrome, it has never looked that good before!
Now she rests until Spring, once again...
This car is optioned very strangely. It's a very low optioned Classic model, it doesn't even have rear defrost. However it has big front and rear sway bars and underbody braces... At the same time, it only has a 7.5 rear with 2.41's. Then it has power locks and tilt wheel.
It's like a clusterfudge of options...
