There's a knock in the front end and I knew it needed them anyway so I changed the sway bar bushings and links.
Minor job for sure, Energy poly kit from AutoZone, 1 hour job. I ordinarily would hardly mention it but I've never changed just the bushings without other work - What an amazing difference! Not all the knock (I'm thinking LCAs) but much of it, the real improvement is in ride and steering. Small old truck goes clattering down the road bump steering to oblivion? No more! Well still a little
but so much better, smooth and stable at the low 70s I do on the highway. Almost like new shocks, no kidding.
One thing, autozones' website showed the bushings to be greaseable, they aren't. So after internet gleaning I sanded and cleaned the sway bar contact points, wrapped the points with Teflon tape, lubed the heck out of them with some leftover Energy grease (I've heard tell it's 'plumbers grease' or marine grease btw) and installed the bushings. If it starts squeaking I'll post.
Anyway run outside and change your bushings right now
Best highest value thing I've done in a long time.
Pete
Pete
