Here's a pic of kind of what the dash will look like. The main difference mine will have the tach and speedometer in the dash. And if I add the cage the crossbar and uprights will be behind the dash.
I haven't been able to work on the car much this week. But today I removed both of the heater/AC units, the ebrake pedal assembly, hood realease cable assembly, both front seats, the door sill plates and got the front half of the carpet pulled up. Now if I can ever afford a sheet of aluminum I can get started on the dash.
Here's the worst of the rust I've found so far. The rocker and upright are rotted really bad. The driverside floor seems solid but I won't know for sure until I get all the asphalt sound deadner removed and the seam sealer pulled up. The passenger side front floor has rust holes at the front seam where it meets the toe board.
Nick
88 Colony Park LS
Damn that is a good amount of rust but not too bad for being 27 years old and a Minniesota car. My uncle has had cars in way worse shape then that aren't as old. My uncle, grandma, and brother all live up in the twin cities.
The way this area is rusted I'd say a hole rusted thru the bottom first and then all the dirt/salt/water got kicked up into this area and just rotted it out.
I'm not worried about it. It's in better shape then I was expecting. There aren't any huge gapping holes in the floor pans(so far ) . Since the car has a full frame it makes the rust repairs easier. And since this is basically going to race car/cruiser it doesn't have to be repaired perfect(as far as looks go ).
I've had many cars and trucks that were a lot rustier then this one. It's a way of life in Minnesota. The cars rust and rust badly.
My biggest problem is I don't have a welder right now. I've got a plasma cutter but I had to sell my welder a while back. So I need to pick up a cheap welder before I can do the repairs. When I do get a welder I'm going to wear it out! With all the holes I need to weld up on this car(just look at that swiss cheese firewall!! ). I've got a lot of patch panels to make and a lot of welding to do!!:welder: :welder: :welder: :welder: :welder: :welder: :welder:
