I'm not going to run the LSC. They are just on the car to keep it off blocks.
I sold my dad's totalled Caravan. He wanted to keep 16" 5 spoke rims and expensive winter tires that were on it. So The LTD gave up it's stock steelies and tires so I could sell the van.
I will be picking up some aftermarket steel rims for it this spring. And the LSC rims will be sold.
And some bad news the I decided not to swap in the 460. I found out the 460EFI motors have a unique intake. You can't swap on a carb intake without swapping heads. And if I'm going to buy heads I'll just go with some good aftermarket heads for my 351W. I can make the same power(or more ) with less weight by using the 351W.
