1994 Crown Victoria
    I'd love to see a write up on retrofitting one of those one touch relays. Is it one relay per motor or per switch? As in, would passenger windows require multiple relays for one touch function at both the driver's door and passenger's?
      The "one touch" option is factory for the driver's window only. Could one be fitted for a passenger window in addition? Would have to see the schematics to tell for sure.
        I know they can be set up for a one-touch up as well, so I imagine adding the one-touch module to the passenger door would allow it to work the same as the driver door. I do believe it's an in-line module for the driver door window motor with it's own power source. That said, I'll try to remember to find that when I get home later as I have the 93/94 service manuals.
          I have to check and see if my wiring manuals are here at the house, i think they might be in the back seat of the Zephyr which in storage right now
              This thread: http://www.grandmarq.net/vb/showthre...-Down-In-a-Box
              You need a module for up and a module for down at each window if you want both up and down. There is now down or up module...they are the same. Function depends on how it is wired.
