Originally posted by Mainemantom
View Post
1967 Mercury Cougar XR7 - Project Green Kitty
1997 Crown Vic - Mostly rust free, moderate mileage. On the road... but far from perfect. **SOLD**
1985 Crown Vic in 2-Tone Blue **SOLD**
http://automophiliac.blogspot.ca/
Hi Folks! Sorry for the long period between updates. Have been regularly plugging away as I am able to. A frustrating process at times as I discover more and more things missing like random screws and trim pieces. These are the risks of keeping a project in the same shop as several other projects! I have all the body panels installed and am trying to get all of the trim on and then reassemble the interior.
In the 1 step forward, 2 steps back column, I will need to remove my door panels again, readjust my driver's door to stop it from rubbing on the rocker panel, and reaffix the weather stripping around that door. I also need to adjust my fenders slightly so the hood fits a bit better. Then install the wipers, washer lines, etc.
Mechanically, needs the idle and mixture adjusted and an oil change. The C4 is a little leaky and slips when it's cold, but it's been sitting for years. I'll top up the fluid and have to get driving a little to see what it's actual condition is.
I'll take some pics the next time I'm at the shop. Haven't been documenting as much as I would like due to lack of time.************************************************** ******************************
Any of those old ford transmissions benefit form am oil cooler.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by jaywish View PostAny of those old ford transmissions benefit form am oil cooler.************************************************** ******************************
Hey everyone! Still alive and still working on the car. Another text update. Been having issues with attaching photos. I'll sort that out one day though!
Car is mostly assembled save for a few trim pieces and interior panels. Driver's door needs a bit of adjusting as I have some slight rub on the door sill.
Transmission Update:
Checked the fluid level at hot idle in park, as per dipstick instructions (always listen to a dipstick). Bone dry. Slowly added what amounted to a full quart of Type F ATF. It's now sitting at the full indicator and it has massively improved the driving experience. No slipping, no whining in reverse, kickdown works perfectly. Why, I'd say the car is almost fast.
Cooling Update:
I have purchased a new aluminum radiator to hopefully address the hot idle issues I've been having. Fan and shroud upgrade keeps her cool while she's driving, but once she's warm she gets toasty sitting still. The hot idle was a little low too, so I've upped that by about 100-150 rpm, which may also help move more air. I bought an ACP Radiator, which has stamped tanks to match the stock look. I painted the radiator black (except the fins) to help preserve some of the stock look.
Vapor Lock Update:
Hard fuel line from the pump hugs up against radiator hose going into the radiator. This is hot. Fuel has ethanol, which drops the boiling point. Bad combo for hot restarts. I installed a tacky insulator over the line and that's solved the problem. Only issue is now the fuel line looks like it's wearing a space suit from a 1950s b-grade sci fi movie. But it's a small price to pay for an easy fix to an annoying problem.************************************************** ******************************
Sounds like it's "just drive it" time. Nice.
Originally posted by sly View PostSounds like it's "just drive it" time. Nice.
Plus a bunch of other stuff but I'll update as I go.
Heres some pics:
