Originally posted by mercurygm88
View Post
My 1983 Continental Mark VI!
2005 Volvo V70 Bi-Fuel
Originally posted by Arquemann View PostThe intake for the pump was literally just a hole in the pump body, atleast on mine. There was only one big hose coming from the pump which went to the junction controlled by the two solenoids.
You can just route the belt around the smog pump and abandon it in place. If the pulley is in the way, it unbolts.
I think the vacuum connection thing came about later on. I don't recall seeing it on CFI cars.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostYou can just route the belt around the smog pump and abandon it in place. If the pulley is in the way, it unbolts.
Originally posted by DerekTheGreat View PostWhy didn't they work?
Usually located right side of the steering column under the dash. Look for the box with a speaker grill (lots of little holes in a circular pattern) on it. I think the stand alone cruise control modules are also located in that spot if equipped, but I could be mistaken on that one.
Now that the Mark VI is in the garage for the winter I've been fiddling around here and there with some little odds and ends. Still trying to get the brake light to go out, I removed the bulb from the dash awhile back. I got bored the other day and put the light back in and it's stuck on. I pulled the plug off the sensor on the proportioning valve and stuck a jumper wire in it and the light went out. I tried contact cleaner but when I plug it in the light still comes on. I'm guessing either the pressure switch is bad or it's sensing low pressure, the later doesn't make sense to me as the brakes are just fine. Is this pressure switch still available? And if so is replacing it going to get me into a situation where I have to bleed brakes?
Hey,
I don't have any info on the brake pressure switch for you but I was wondering if you are familiar with the television series Supernatural? In particular I like Castiels' car starting in season 9.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
its not actually a pressure switch. it reads whether the slide valve in the prop valve assembly is moved one way or the other. Either its not centered, or the switch is just bad. No idea if its available or not.
part number is D9BZ-2B254-A for all 80-83 Mark VI and basically everything else that uses that sort of valve assembly. Official name is "switch, brake pressure differential valve warning lamp"86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postits not actually a pressure switch. it reads whether the slide valve in the prop valve assembly is moved one way or the other. Either its not centered, or the switch is just bad. No idea if its available or not.
