Trunk Rust Proofing / Leak Fixing
The trunk has been leaking since I got the car. I finally got around to patching it up similar to how how I did it on the Crown Vic when that had the same issue. This leak isn't that bad but it definitely needed to get done. We're in for some heavy rain tomorrow into Thursday so it should be a good test to see if this actually worked.
View of the before with all the tail light stuff removed. Notice that the little filler piece is still on the driver's side. That's because whenever the previous owner had the rear quarter panel repaired, the body shop glued that to the rear quarter panel so it will never ever come off without ruining it.
Not too terrible from afar but up close it's a bit more chunky. On the inside, all the paint was flaking off and under it was all surface rust.
I grinded down all the rust and then cleaned everything. After that, I coated that whole back panel with POR15 inside and out.
I patched the small holes and breaks in the seam sealer with regular water proof caulk sealer from home depot. Then hit the whole thing with a layer of Rrustoleum. It's definitely not a perfect match to the light color of the two-tone paint job but seeing that this area is 99% covered, it doesn't really matter. The spray can enamel actually came out much better than I thought it would have.
Color match looks closer here:
Like I said before, the driver's side was hit bad at some point. When I had the tail lights off, I noticed that there were two different types. The one in the top image is from the passenger's side which may be original. The bottom one is fro the driver's side. On the outside, they look the same but the foam weather stripping is different.
Anyone have any idea why there's a difference? The passenger's side's foam is SHOT. Holy crap. The previous owner put more of that tacky crap they did on the one rear light bulb to try and hold the foam on. Needless to say, it didn't work and I've already lost one bulb because that side gets water in it.
Are there any good replacement foams that I can try to replace it with?
