I did pull the plugs last summer, I think, and found some evidence of fouling on the back cylinders. If I check them again then I'll probably just throw the new ones in since they're ready to go. Wires could also be trouble. I've replaced one or two from the connection breaking after I pulled them. Maybe another is getting loose or otherwise not seating right.
On the suspension, all the rubber is fresh on that front right side except for the lower control arm bushings, which are shot. But I would expect those to make more of a clunk than a lighter rattle. Brake hardware also looks to be good, and the wheel covers are tight. It still rattles even with the wheel covers off, so that's not it.
I should've said with the paint that it's single stage. I've compounded and polished the hood before and the pads turn black, so there's no clear. Whatever they repainted it with is on the soft side. I should probably figure out what kind it is so I can match with the touch-up.
