Thanks, Vic. I managed to get the spindle free and out of the way, still connected at the tie rod. Nearly got away with keeping the rotor on, but the dust shield seems to catch the lower control arm when lifting the spindle off the lower ball joint. Not a huge deal, and now I can compulsively clean the dust shield, which is the first '70s Ford part number I've noticed on this car.
Both ball joints were completely encrusted in greasy dirt, and while I can't see any damage on the boots it must be there somewhere. The upper ball joints appear to be original, while the lowers have grease fittings, which I assume means they're replacements. Not sure how bad these joints were. The upper will move freely with little effort, while the lower is easily moved in and out, but gets hung up when pushed forward and back. Compared to the replacement Moog joints, they're a lot less stiff, which hopefully means they were wearing out.
Right now I'm hung up on pressing out the lower ball joint. My Amazon press is maybe 1/4" too short to fit over the adapter cups it comes with. I'll see if I can buy some more adapters to get it to fit. At this point it'd probably be easier to just rent one from O'Reilly, but I've got money sunk in the one press tool already.
The other thing I see is cracking on all four control arm bushings. If I did the lowers I'd have to buy a spring compressor. The shop manual shows one with two plates that sits where the shock lives and squeezes from the inside. Most ones on Amazon, though, seem to squeeze from the outside, which I believe would be blocked by the frame or control arm.
The upper control arm could be done without messing with the spring, but it looks like the hinge pin runs through both bushings and would get in the way of a c-clamp style press. Is there some special tool for doing these?
