I gave up on the swap myself, but heard they'll run just fine on a Mark VII HO ECM. Don't think you can use the intake, although WTF do I know any more? Someone who does will hopefully comment.
Prudence, my 87 Town Car
basically you strip it to the long block. Timing cover, water pump, all front accessories, and the oil pan do not work. You also need the threaded dingus that goes in the oil filter spot on the engine. Exploders have either a remote or a cooler, don't remember which but a filter won't screw in there unless you put the part in.
Mark VII ECM works questionably. they tend to run lean because of the extra air flow.
Intake works if you disable the EGR, or use the early one if you want to retain EGR.86 Lincoln Town Car (Galactica).
So what is the preferred ECU solution for these GT40 heads? Aftermarket? I thought that with mass air the computer would be able to compensate better for any extra air.
Originally posted by Lutrova View PostSo what is the preferred ECU solution for these GT40 heads? Aftermarket? I thought that with mass air the computer would be able to compensate better for any extra air.
My Cars:
I’d be interested in what an aftermarket ecu like a mega squirt would do. Probably not much but it would be interesting to see. Plus the ability to datalog would be nice.
Op since yours is an 87 you can use a mustang ecu, which seem to be a little easier to find. I have one from an 87 mustang on standby for when I eventually go swap my 87.
I assume I can run a Mustang ECU because my '87 has standalone cruise control?
If I understand correctly then, the critical thing is that the fuel injector size and firing order match the computer? The computer should be able to compensate for greater amounts of air, at least with MAF conversion, but it's expecting an injector of a certain size that can't be changed without a tune?
And if my goal is just to take advantage of the power from Explorer heads and intake without pushing for anything crazier, then the 19# injectors should be sufficient?
I'm already running the '90 Town Car air intake with a MAF, so swapping from speed density is definitely an option. I'd just need to plug it in and I guess re-pin the ECU connector.
It's been nice so far to upgrade incrementally, but at this point I think I'll have to do the head, cam, injectors, intake, and ECU all at once. Maybe I could swap the intake and throttle body before the rest, but my stock speed density computer would probably wig out.
Although having said that, I suppose the '90 TC air box and intake could be a restriction going into Explorer stuff, and the tubing wouldn't fit an Explorer throttle body anyway.
Three months later and somehow I'm just getting around to getting this car back on the road. I see from old pictures that I've managed to put under a thousand miles on it in the last 11 months. And in a little over a month from now I'm hoping to drive it to San Antonio, about 1,400 miles away. It's not my brightest idea, but with the price to ship a car and rent another or fly, I figure I can have a minor breakdown along the way and still come out ahead.
The problem that took the Town Car out in March was the alternator. A junkyard replacement was acquired pretty quickly, but it was a little chunkier than the old one and I had to buy a grinder to shave down the alternator bracket - something I probably should've done when I first upgraded. It's now much easier to slip the belt on. I also had some coolant leaking from a few hoses that needed to be tightened after I replaced the heater core. Nothing major, but the heater core had been something I didn't want to drive with while leaking, and the alternator obviously left me dead in the water.
But having addressed those issues, the car should otherwise be in decent shape. I backed out of the garage this afternoon for a test drive, only to find it slipping out of gear all the way around the block. After stumbling back into the garage, I added nearly 2 quarts of trans fluid to get back up to the hash marks on the dipstick. The output shaft seal was recently replaced, but the bushing must be shot or I screwed up in some other way because I appear to be losing fluid from that area. I had no idea just how much though since the puddle flowed into a joint in the concrete floor and disappeared. Hopefully my short low-fluid trip hasn't nuked my trans. After topping it off the trans seemed to run again as well as it ever has, though it was making some funny noises while idling in Drive.
In no particular order, the other things that caught my attention during the day's test drive:
- The AC compressor makes a sort of clacking sound, but it still cools just fine so I'll probably leave it be and hope for the best.
- There's a vacuum leak in the ATC system again that causes cold air to drop under sustained engine load. I've tried capping the vacuum diverter valve as it came apart during heater core replacement, but more investigation is in order. The ATC sensor is still working so I'm hopeful it's not the culprit.
- The horns aren't working. Could be the relay. It isn't the fuse.
- I can hear what I think is lifter tick coming from the driver's side of the engine. Sounds a bit like a sewing machine. Not sure how worried I should be about it or what my options are.
- The fuel gauge, which I've been agonizing over in another thread, remained remarkably consistent and, I believe, accurate throughout the day. We'll see how long that lasts.
What keeps me up at night, though, are the two leaking core plugs on the block. There's no coolant drops below the car, even after sitting for three months, but I'm sure they're losing fluid under load. I just don't know how much, and I'd hate to be out in the desert somewhere and find I'm overheating because of it.
Turns out today was Juneteenth, so every place I tried going to was closed. Still, it got the car out and about. This week also marks a year since I uncovered the white walls. More like cream walls, as white seems like more of an aspiration with these tires.
Switch to Evan's coolant to avoid stressing out weak seals due to pressure.
The horns in my Town Car stopped working too. I had to adjust the little screw on them to get them back into shape. The other one turned out to be NFG and had to be replaced.1985 LTD Crown Victoria - SOLD
I'd replace ALL the vacuum lines, under the hood, along with the check valve for the ATC. On that kind of trip, your cool ass will thank you! I'm sure you'll address the other issues as well. Getting back to the vacuum lines - I did them on my friend's car by using the next size larger and simply put them over the existing lines. They were so brittle but that has worked out great!What I Own: 1993 Mercury Grand Marquis GS
Fine steel wool pads (ones with soap) are a really fast and easy way to get your "cream" walls to white walls again. I've done it twice on mine.
Derek : I agree that Evan's coolant is the ultimate solution. But I doubt I'll have enough time to properly convert to it before the trip. Will probably just carry some coolant and several gallons of water in the trunk - both for me and the car.
I hadn't considered the horns were bad. It struck me as more likely one relay would fail than both horns, but since I have the replacements I suppose I could connect a couple of them and see if I get any sound.
Frankie : Nearly every vacuum line in the engine compartment is fresh now, except perhaps one or two at the smog pump valves. Did all those lines two summers ago. But yes, I'll have to go through the whole ATC system again, starting with the usual trouble spots. Prior to the heater core failing, though, everything was working properly, so I suspect the culprit is somewhere on or around the heater plenum, which still leaves plenty of suspects. On the other hand, this vacuum leak is only really a problem in places with large elevation changes. Once I get East of the Rockies I may never again drive through terrain that would cause this issue.
Arquemann : I used something similar when I first uncovered the white walls. Some kitchen scrubbing pad, though I don't recall if it had soap in it or not. The trouble is these tires never stop blooming. My wife's Honda came with Firestones that never seemed to brown. Of course, the sidewalls cracked in under five years, so maybe you just have to pick your poison. But I am a little jealous at all the long discontinued tires on cars in the junkyards that still have perfectly white stripes, even though the rest of the tire is kaput. I wonder if better tire makers had a handle on blooming in a way the budget guys don't. And now that white walls are so niche, it seems like you're either shelling out for Cokers or getting the cheapos.
I think I found out the horn was bad by putting on ohm meter on it. There's a spec for them, 0.6-1.2 ohms maybe. The one that was bad worked, but it was the culprit- it was something like 0.2 or 0.4 ohms when I tested it. I tried adjusting the screw on it, which affected the resistance. I'd get it in range, run the horn and then it would go out of range. I messed with that for a while before tossing it in the trash.
Car looks good by the way, very formal. I dig the wheel covers.1985 LTD Crown Victoria - SOLD
