My 79 Marquis
    Oh, I see a project I can help with. I have no idea the if '79 floor pan is the same and will accept that '87 seat track.
    Did you get the harness from under the donor carpet to plug in to both the driver and passenger seat? Other than that it looks like everything I would need as long as the floor pan is the same.
    Vic
      The brackets seem to match after a crude measure. One difference in the 79 seat is that it doesnt have a lever on the side to manually recline. Didnt grab that harness, damn
      1979 Marquis creamy goodness
        Not a deal breaker, a harness isn't too hard to make up. If you do get back to the JY pull the driver seat out, pull the carpet up, and get as much of the harness as you can. Should be just two wires. One is a bolted on ground wire and cut the other wire, somewhere along that floor channel just inside of the driver door.
        Figuring out the physical mounting of the switch will be fun since '79 has that trim piece on the side of the seat that I'll have to figure out how to not mangle in the process.
        Vic
          Been there! Maybe this will help:
            That really is the beauty of having access to the Metro Detroit area...these cars are so common (as I think my junkyard thread has demonstrated), that parts which would otherwise be expensive or difficult to find are at your fingertips for pennies.
            It won't be this way forever but it's pretty great while it still is.
            | Junkyards
              Well said, kish.
              Me and Vic talked about this the other week....I think there is about 3 to 5 years before most of everything will be gone. Not sure if we have a master parts list on this site for parts that people need and have. It may be a good idea to start a thread listing things/inventory for the benefit of this awesome car club...if not we will all be regulated to shitty parts on Egay.
                *Ebay.
                  It is easy to change the seat over to manual recline. It is just a bracket assembly on lower and upper frames. I did it on my 90 CV. Just have to move the seat cover up and around a little. If there is a aluminum trim cover on lower seat cushion, a hole will have to be drilled for the lever.
                  I would be harvesting as many parts from that junkyard car as possible if the prices are reasonable. EBay prices are really high. JY availability is becoming less every day.
                    I did not know that about the recline, good to know. Good thing he got the whole seat.
                    Vic
                      FYI The brackets are not on both sides of the seat, only the outside
                        Thats a great heads up. You saved me some four letter words.
                          VV carb is off. My vaccum lines have vaccum lines, gonna delete some.
ID:	1288172Click image for larger version
                            ahhh that mess of vacuum lines brings back memories of my VV days
                            -Phil
                              Wow, and I thought our '79 G10 was bad with all of its vacuum lines.
                                I filled an entire 30gal trash can with the stuff that came off my 84 wagoo when I went to a carb with a duraspark2.
