My 79 Marquis
    Yeah... lots of fine thread stuff in cars.
      Back at it
      1979 Marquis creamy goodness
        The "fun" never ends, does it!
          Good stuff. Keep at it. Its worth it.
            Realized after paint, my trim will stick out nasty ish , so removed it and am left with just a quarter inch of adhesive, backing. Stuff is on there
            Should I leave if off?.
              You're going to have to clean off the old adhesive anyways if you want to reinstall the trim. Those fudge-looking adhesive remover wheels and a bit of heat works wonders on the old adhesives.
              Unless the trim is hiding some damage, I'd leave it off. I kinda like the slickside look of the fleet-spec LTDs.
              2005 Volvo V70 Bi-Fuel
                I used this for removing that adhesive goo from a spare set of doors recently. It worked really well.
                Click image for larger version  Name:	s-l1600.jpg Views:	0 Size:	372.0 KB ID:	1390053
                Id leave the trim off after the paint job. I feel the cleaner look is worth the absence of the trim.
                I also fear the trim wont stick as good as original and peel up in the corners.
                  All good advice, appreciated.
                  The below is $15 delivered or half the cost of the 3M and should do the trick. Thinking about getting a full paint job. The antique cream color since 79, to color match that after the age may not transition that well. Price is neglable to a spot paint job....getting that part professionally done.
                  Yeah, gradma trim will be not be placed back on
                    Yeah those adhesive remover wheels wear out pretty quick when used so I see no point in buying the expensive ones. My 5" 9.99€ no name special has worked just fine. I've used it to remove the old decals off Maisa's ass and wheel weight glue from 3 sets of wheels and still about half left on the adhesive remover wheel.
                      +1 generic "eraser wheels" work fine. I've got a couple different versions (regular and heavy duty - kinda looks like a tall LEGO wheel) of the Amazon specials and I've used them for probably about one door worth and it's held up fine. Still plenty of wear left.
                        Heat gun and eraser wheel def right way to go.Some paint on the border, deep sixed. Like the look without it, def more clean. Gonna start to remove the paint.
                          Originally posted by Grand1 View Post
                          Does anyone have the bolt size to the header panel to fender? Or an alternate bolt that would work? The one I saved is MIA. It looks like this:
                          I've got 9 studs, and the nuts that go with them, that I think will work. We'll see next time I'm over there if what I have will work.
                          Vic
                            Thanks to Vic for the hookup on those fender bolts/ screws whatever da Fook they are.
                            So it got the metal brackets for the window regulators...thanks again Wagonman, looks like the arm is attached with a plastic piece, that slides in the groove. Since I have the metal ones, does it matter that I will be using plastic, in a metal bracket channel?
                              The newer regulators use the plastic on the metal brackets as well! You are good to go! WagonMan
                              89 Colony Park
                              90 Colony Park
                              70 HEMI Daytona Convertible
                                Those studs the right thing? I'm fairly certain they are. If so the source, for those wondering, is '98+ outside mirrors. And being pretty well protected by the mirror assembly and door they tend to be in great shape.
                                There was a '94 in the JY but the studs were not removable and not quite the same on those mirrors. Not sure if those studs changed in later whale outside mirrors, but for sure '98-'02 is a good source for them.
                                Hanger bolt I think is the technical term.
                                Vic
