Drug the lopo with 26k on it out of storage.
It’s not pretty. But maybe it will be soon. Had it not gotten dropped by the forklift operator in the junkyard, it would look much better. It shattered the exhaust manifold on the other side. It came from an 88 wagon that sat near my dads house forever, literally the state inspection ran out in ‘92 I think. Then it disappeared and reappeared in the junkyard circa 2015. Cream puff wagon death. It’s heart will live on. I saved the trans too.
The plan is to clean it, HO cam it for the sound, reseal everything but head gaskets, install correct oil pan and timing cover for the Mustang. And paint. I don’t really care about high performance, so it’s keeping those E6 boat anchor heads for now. They work good from idle to 2500 rpm at part throttle. That’s kinda where I drive 99% of the time. This car weighs about 2500lbs I think. So 200hp will give me a power to weight of a 300 horse panther. Marauder style. I’m so bad I’m even ditching the aluminum intake the tired old 302 came with and going factory cast iron. At least it’s a 4-bbl. I was going to run a 2-bbl if I used an AOD.
Gotta refigure the accessory drives. The car came with a mixed up set of unaligned belts and pulleys. Part Mustang, part F100, and who knows what else. I planned to use a 74 Torino (wagon!!) donor setup that I have handy, but the depth is wrong and puts the fan too close to the radiator. Aftermarket stuff looks cheap. Will seek out factory style. Technically any pre-70 stuff with work.
Trans is ready. Ready to try at least. Put the shorter fox style input shaft and steel bearing retainer in. Not sure if the guts are good but going to take a small gamble. It looked nice inside. Worse case I pull it out again and rebuild.
Ordered adaptors for the bellhousing to mount the T5 and some other stuff to make this actually run around Christmas. Vroom vroom.
