The game might be over before it even started...
In stock form, does the TV lever at the trans bottom out at WOT?
In the pic below, TV rod adjustment is maxed out, the trans end is bottomed out, and I'm missing about that much on the rod... When attached to the carb linkage, it does do full sweep of the carb-end movement.
I could probably bend the TV rod, but I don't know what kinda clearance issues and wonky geometry issues that'll entail...
