I got the parts today, started installing the new strikers.
Now I've got a bit of a problem...
The door shut too "deep" with the new striker and it's not opening.
It's not locked, the handle has tension and I tried pushing against the door and pressing it up and down while trying to open it.
I put the new striker in about the same location the old one was in, pretty middle, though I suspect the latch in the door has been adjusted aswell before.
The latch adjustment is done from the doorjamb... How the hell do I open the door?
Can I get things loosened from inside the door? I need to remove the door panel anyways.
