Looked through all of my manuals and did not find a spec on this. In the NVH diagnosis it says to check it and replace the axle if excessive but it doesn't bother to give any measurements.
Pop the axle and inspect it. if you see no damage to the machined surface, stick it back in and roll with it. If the area where the bearing rides on shows any kind of damage, replace the axle and the bearing.
