Usually the bucking at those speeds is related to misfires. Might need to check that the timing isn't too advanced and the wires are in the correct order (sanity check).
+1 checking for vacuum leaks - especially from the throttle plate down. Some leaks may not present until under throttle if the lines are hard or have a hairline crack.
If the lines rub off on your fingers, they're probably porous enough to cause problems under load and need to be replaced. I remember dealing with that on a chevy 305 with a quadrajet on it. Had to replace about 18 feet of vacuum lines. Then it ran great.
