Bloody f'n Escape.
Squeak from accys, pull belt, no squeak. Alt is relatively new, spins free, AC pulley spins free, tensioner hitches & makes tiny noise. Rpl tensioner. No change in noise when ac cycles.
AZ swapped alt.
Now ALT DOES NOT CHARGE.
Had it in and out repeatedly, chk'd fuse & mega fuses at power block, connector does not appear damaged. Have 12 v on red wire @ alt.
Took alt to AZ tested good. Took car to local shop, they think it is the alt.
Don't know what to do next.
Have to get car back together before they call me in to work.
Any ideas?
2010 3.0 V6
__________________________________________________ __________________________________________________ _______________________
Cables are good, terms clean & tight.
Code P0620, Generator Control Circuit.
PIDs Gen Command Line Fault
Generator Fault Status Yes
Gen Monitor Line Status Fault High
I get battery voltage when engine is running. Batt Light comes on.
If I rev it up to about 3k it will start charging at 13.8v which apparently is a failsafe mode. It always ran at 14.5 to 14.7 before.
Have 12v @ stud to battery.
I cannot reach to probe 3 wire connector when connected to alt.
Disconnected I read
KOEO KOER
red/brn 12v 12v
grn/or .06v 1.9v
Purp 12v 12v
Took it to an auto electric place purported to be the best in the area by someone i respect. The owner told me they do not believe the alternator is a quality part (from a national chain).
He said "Yes we are here to make money, but not by ripping anyone off" "save yourself my markup and labor charges" "The first thing I will do is replace the alt so go get one from NAPA and replace it".
Unfortunately that did not fix it. I am getting concerned that this may be a PCM issue.
AZ swapped alt.
Any ideas?
2010 3.0 V6
Disconnected I read
KOEO KOER
red/brn 12v 12v
grn/or .06v 1.9v
Purp 12v 12v
