That was my understanding as well, based on stuff I read a few years ago so I wasn't sure.
I know how the car behaves with a mechanical key when I try to start it (stock PCM). With the ARA3 and any key it seems to do the same thing. I'll admit that the way I had the PCM connected left room for it to not have a good connection. I didn't tighten the connector bolt, but it seemed all the way seated. I'll try with the connector bolt tightened, but you have a good point. I don't know of this PCM is good. I got from a JY about a year ago figuring I would sell it only to find the price for these used online was down considerably at that time. (I've sold a couple of ARA3s in the past, so I had a good idea what the typical online used price used to be.)
My guess would be that there probably is some communication back and forth between the PCM and PATS module. When your PATS module never receives a response from the PCM it knows the conditions for starting aren't met so it flashes the light. The PCM not being configured to respond/react to the PATS module goes ahead and allows startup.
