Well, I've been here a year with this old beast, so I suppose I should post up a build thread and some pictures.
The car is a 1986 LTD Crown Victoria 4-door:
Serial Number 2FABP43F1GX21xxxx
2FA Ford Passenger Car, Built In Canada
B Active Seat Belts
P43 LTD Crown Victoria 4-Door Sedan
F 5.0L 302 V-8 EFI Engine
1 Check Digit
G 1986 Model Year
X Built at St. Thomas
21xxxx Serial Number of this Ford scheduled for
production at St. Thomas
07/86 July, 1986
8Y Dark Clove Brown Metallic Paint, Ford #5973-A
16 Philadelphia DSO (District Sales Office)
54K LTD Crown Victoria 4-Door Sedan
D4 Clove Brown Valino Rear Half Vinyl Roof
GC Clove Brown Cloth Split Bench Seat
8 2.73 Conventional Rear Axle
T Automatic Overdrive Transmission
As received, it was a time capsule. I'm the 3rd owner.
Your vehicle was equipped with the following features:
- Front License Plate Bracket
- Interval Windshield Wipers
- P205/75R15 Wide White Sidewall Radial Tires
- Electronic Digital Clock
- Tilt Steering Wheel
- Speed Control
- Power Driver Seat
- Bumper Rub Strips
- Air Conditioner - Manual
- Electric Rear Window Defroster
- Right Hand Remote Control Mirror
- Power Windows
- Locking Wire-Style Wheel Covers <--I got the car with a nice set of turbine wheels which the owner claims were original.
- Rocker Panel Moldings
- Clove Brown Valino Rear Half Vinyl Roof
- Tinted Glass
- Light Group
- Power Lock Group
Otherwise, the car had about 75000 miles, pretty hefty documentation, new tires and new exhaust. There's a small dent by the passenger side rear wheel arch and there was a rust hole about the size of a dollar bill where some leaves got wedged under the driver's side of the transmission crossmember (which is gone now).
I've put on about 8000 miles, daily driving. So far I've done a tune-up, HO intake/replace all the vacuum lines, valve covers, battery, new radio and front speakers, minor interior cleaning, trip computer (not the tripminder), air conditioning, and most of the brakes/suspension/steering.
Approaching plans:
Poly bushings/Bilstein shocks
Police sway bars if I can find them
3.55 gears with Trac-Loc
Rear speakers (currently none and no wiring--I think the original radio only had front speakers; it barely had those when I got it)
More gauges-water temp, trans temp (for towing), oil pressure, voltage, tach
Transmission cooler and replace TV cable (mine isn't broken yet, but the front clip has been JB-welded and can't be adjusted anymore)
Repair peeling interior "chrome" with replacement parts
3G alternator and electric fan
Timing chain/water pump/power steering pump/belts/hoses/radiator/thermostat because I'm in there and I have new ones.
Later plans:
Since I have 2 very good sets of 15" tires on wheels, gathering parts for the big brake swap but I'll wait until the tires are worn out first. I'll also need to find wheels (I have 17" Mustang Mach 1 wheels I could run with spacers, or I could save those for my Zephyr project).
Story of the Walrus Brown name and pictures will have to wait until I've had coffee and some time to settle into being home after a month at work. Came home to a blizzard, a dead snowblower, and a locked up starter and of course the car has my F150 blocked in so I changed the starter in the snow. Fortunately Ford used all of 3 starters from 1965 to 2004 in their RWD engines, so my spare F150 starter went right in (I could have used the Mustang gear reduction, but it was cold and snowing and I didn't want to spend even 5 minutes running a new cable.
Also, that spare starter was a "new" one I bought about a decade ago. The part number sticker was peeling, under the "NEW" sticker was.."Remanufactured in China". It works and I'm not in a hurry to change it, but WTF?!
B Active Seat Belts
1 Check Digit
G 1986 Model Year
07/86 July, 1986
- Speed Control
- Power Driver Seat
- Bumper Rub Strips
- Power Windows
- Tinted Glass
- Light Group
- Power Lock Group
Approaching plans:
Later plans:
