Nice engine and I am digging the stand it came in on.
'Sherrie' my 86 Oxford White CV Coupe
Originally posted by packman View PostBeautiful! I see you got carb'd valve covers. I would think that you shouldn't have fitment problems with those on a 8.2 deck. Hope that beast is running and cruising soon
My current thoughts are on which fuel rail to use to properly accommodate the regulator.
Originally posted by 87gtVIC View PostNice engine and I am digging the stand it came in on.All FORD All The Time
Making a mount for the throttle cable mounting bracket today.
My original plan was to make one out of 12ga steel that went in between the EGR plate and the TB. Kind of a flat plate with a bent tab that the bracket could bolt to.
One extra gasket and done.
That plan changed.
Today a piece of inch x inch and a quarter x 4 inches extruded is being welded onto the side of the BBK EGR plate. When I get it home and get garage time, I'll put some pix on here for your visual enjoyment.All FORD All The Time
Here's the mock up of the throttle bracket. Seems fine to me.
Since the white paint got killed from the TIG heat, I think I'm going to make it Corporate Blue.
Mock up on the bench..
Being an extruded piece and a cast piece, it took a BUNCH of amps to get them hot enough. 80 amps was the first try and all it did was melt the filler rod.
A local woman has been the legend of welders around here and she has a huge Miller.
130 amps made it melt like butter, and her legendary status remains intact.
Kathy Haupt in Danville PA.
So that's where I'm at ya'll....All FORD All The Time
This full-time employment shit is for the birds. Didn't miss a day of work through this 'plandemic', and picked up everyone elses slack.
Coming out the other end of this mess and seeing the stalled projects and work that now needs to be caught up.
Hopefully Sherrie can be rolling with a new heart in 2 weeks. FINGERS CROSSEDAll FORD All The Time
I hear ya! When the pandemic first hit; my hours were cut to 40/week. Found a good amount of time to catch up at home and such; more-so when our office was quarantined for a month. But after that, it's been hard to get time to work on the CV and the other vehicles. All I can say is keep chipping away and don't rush.
Took a well deserved weeks vacation. Got the motor swap into Sherrie started. Decided to up the fuel pump game too and went with the Aeromotive 11540 pump.
Gonna take a hard look at my brake booster and fuel return line while she's wide open...All FORD All The Time
Originally posted by packman View Post^^^^^^And so it begins.....^^^^^^^
Once this is ironed out and I become semi-fluent in Mega-squirt... I'm going to be looking for someone to replace my padded top.
It's lifting on the drivers side edge of the back window.
As we all know, fix it now or the car will rot quickly.All FORD All The Time
A few pix to let ya'll see where this project is at.
Original '86 Lopo out. It's kinda neat to see how much was wrong and how Sherrie just kept going.
These really are great cars. Not sure what I'm going to do with this engine. I think for now, it'll go on the little stand and go under the bench where it's safe.
Yep. This FS-6 compressor is toast.
Out with the old, in with the new. We're going from the 150 hp/270 tq to an estimated (low) 350+hp and 410tq.
Desktop dyno says peak hp is going to be at 5500 and peak tq at 3300. Thats a nice power under the curve prediction. I hope it's right.!!
Dressing the new bullet/heart for Sherrie. I'll be doing the 3G swap over the winter.
Normally an O2 sensor here. Gonna put one on the passenger side in the down pipe before the cat. DIY tuning/Megasquirt says you can even put one in the x-pipe. Only 1 is needed.
Stalled for a few days waiting for a 5/8 pulley spacer. No shop near me has anything even close to that so I had to resort to ordering it and waiting. Fluidamper makes one that is plain aluminum and appears to be exactly what I need.
Got that gigantic oil pressure sender in there. Barely. My cupholder/gauge creation will be telling me the oil pressure and water temp news.
At some point in her life, this hose got cut to install a shut off valve. No idea why... it's going away unless ya'll can convince me to keep it..(?)
So it's on hold for now until the spacer shows up. The brake booster, the fuel return line, and getting the parts together to make a filtered air intake of some kind are next.
I might try an alternative mounting of the stock airbox and flipping the snorkel (or one for a Mustang) under the bumper.
I always liked the March performance kit but that price is brutal..https://marchperformance.com/ford-19...kit-p1410.html
So that's where I'm at....All FORD All The Time
Looking good.
What you are calling a "shut off" looks awfully similar to the factory thermal blower lockout deal. Jump the wires and cap off the vacuum lines and be done with it.~David~
Originally posted by 87gtVIC View PostWhat you are calling a "shut off" looks awfully similar to the factory thermal blower lockout deal. Jump the wires and cap off the vacuum lines and be done with it.
@clutch47
-What are you doing with your smog pump? Is it just there as an idler and ballast?
-Are you staying with the stock TFI? I spy a TFI module there and wonder if the new fancy engine could benefit from a more powerful ignition system.
Originally posted by Arquemann View PostWhat controls the shut off? I'm just wondering if anything is really won by removing it...
@clutch47
TFI for now. We'll see how that works.All FORD All The Time
Originally posted by 87gtVIC View PostLooking good.
What you are calling a "shut off" looks awfully similar to the factory thermal blower lockout deal. Jump the wires and cap off the vacuum lines and be done with it.All FORD All The Time
