I've been a busy guy lately, but here's where I'm at.
1/2" Phenolic spacer in the mail to Big Dogs porting to be matched to the stage 3 opening he has this intake opened up to.
It's an inch and 3/4 hole for each port I believe. I'll measure and post a picture.
Truly...SO FAR.. Tony at Big Dogs has been nothing but awesome. He's never once left me hanging on a message or failed to produce.
With my engine configuration and torque cam, Tony's engine program gives the numbers of 340 hp@ 5200 and 380Tq @ 3800 at the wheels with a 15% loss factored in. Power under the curve.
I'll probably never dyno the car on a chassis dyno and my butt dyno is out of cal.
My target was HP above 3hundie and fun to drive, Double the power of the FoMoCo Original issue LoPo.
Should work out well.
The balancing on the rotating assembly is done, machine work is done, and final assembly is happening a little every day.
My engine sen-sei has been tending to the loss of his brother in law, So we were stalled for a while.
All the parts are in order except injectors.
Anybody got good info for me.? I'm thinking 40# or better if I can do it.
Like I've stated here previously I've never done an EFI performance build, so... WEEEEEE here we go...…
I'll probably upgrade the fuel pump at the same time as the 'LoPo out/347 in' happens.
I really did want to go through the pains of making the Speed Density computer work just to do it and learn from it.
Aaaaaand that changed.
It's Mega-Squirt for me.
I've discussed this with ya'll for 2 years, and I'm done jacking with it. Plug and play has SERIOUS value.
I'll throw a pix or two on soon to show ya'll where we are.....
