The Crown Shit. The never ending story.
    That is where the vise grips Dave mentioned come in.
    Congratulations on getting mobile.
      i had vise grips clamped on as tight as possible. just kept rounding off. said eff it and moved on to the other three.
      Ray
      1997 Crown Victoria LX "Crown Shit"/"Crown Marquis" SENT TOI SCRAP
      1986 Ford Mustang Notchback
        How good are the teeth on 'em? Once the teeth wear away, you might as well throw 'em in the trash..
          they were some solid ass teeth, got the rest of them cracked with them tho
          Ray
            Sounds like it's time for a new caliper on that corner.
              might do that eventually actually. i need to get my shit together and decide if i'm really into keeping this before i spend any more on it.
              Ray
                well that was.... eventful.
                jabbed the brakes and the pedal went right to the floor.
                goddamn bleeder valve wasn't tightened all the way.
                But it's in it's rightful spot in my driveway until i work up the courage to get to that in the next day or so. While it's in my driveway i'll get to the speedo (probably) and the O2 sensors that aren't plugged in.
                Ray
                  Ray
                    one more thing, i switched off Overdrive before taking off, but now it seems that it doesn't want to get switched back on, it's just flashing in my cluster now, thoughts?
                    Ray
                      Check the codes. That means there's a transmission code.
                        just realized that.
                        ALSO, took apart the old trans.
                        yeah.
                        Ray
                          oh hell yeah.
                          just my luck.
                          a brake line popped. FR, where it turns up and bends around the frame.
                          fuck.
                          Ray
                            Thats the thing. You fix one spot and now you find the next weakest link. It is a battle until it is all replaced.
                              went ahead and took off the line going to the FL.
                              getting to that splitter block is a PITA. fighting with fender liner for a solid two hours makes a 17 year old kid real angry
                              Ray
                                In time you may learn/realize spending a couple extra minutes removing stuff from your way may end up saving you struggle/hassle and time in the long run.
