Nice. Make sure to toss that TFI so not to go through this issue again with any of your other windsor motors.
The MEG (My 86 LTD Crown Victoria Coupe)
I got the pleasure of driving "the Meg" the other day. Fun car to drive, with lots of mid range and top end power, but decent low end grunt too. Great throttle response and easy cruising. Handles well around the corners (going to be a beast with stiffer springs). Johns tuner thinks the current stock shift points are fine, but it felt like she had more in her than that. I really want to see what she'll do at the strip, so I will probably be going with John if I can.-Phil
So I am currently planning out a beefy 351W stroker swap and I found this thread. I have a few questions,
Did you have to cut the hood at all for the Lightning Intake?
With the lightning intake and BBK TB, did the stock throttle cable/IAC Valve/Speed Control all connect?
What did you do for swapping to serpentine accessories? It looks like a custom bracket for the AC Compressor and Tensioner, and I'm assuming the water pump is for a Fox Body?
Thanks!1986 Country Squire
1969 Mercury Cougar
1960 Land Rover Series II 88"
Originally posted by kellen302 View PostSo I am currently planning out a beefy 351W stroker swap and I found this thread. I have a few questions,
Thanks!
The throttle cable, tv cable and cruise control are all stock. The bbk throttle body was modified to allow for stock bell crank to fit it. The lightning egr spacer has provisions for both the box panther and fox body throttle cable bracketry.
The AC brackets are off a police package box with a 351w. They are 351w specific. All accessories are box panther. There is a brace bracket that attaches to the intake manifold that had it's own boss on the panther 351w intake. That is not present on the 351w lightning intake. So I modified that bracket to fit on the most front intake bolt. I also modified the brace bracket from my stock 302 alternator bracket to fit and clear the 3g alternator on the 351w. I believe I posted pictures of this. If not I will go through the thread and dump all of my pictures I have of the project. I also used a longer bolt for the bottom mounting bolt of the alternator. I used the stock box 302 power steering/ alternator bracket but removed the threads for the lower bolt. The lower bolt for the alternator bolts directly into the cylinder head instead of the bracket. The alternator belt is the same length as stock 50.5" 5060505. The ac belt is longer. Without smog pump it requires a 60 inch belt. 506060.
Originally posted by kellen302 View PostThanks for the quick answers! I'm putting all my notes and parts lists in a big spreadsheet. I'll try and do a big writeup after I finish.
Picture Dump
You can see I finally got my head out of my ass and installed the Powered By Ford valve covers, and swapped over to the 39lb fuel injectors. At this point the engine is ready for install. Also painted the egr spacer and throttle body while it was assembled on the upper intake.
Picture Dump
In this collection. You'll see the rear from Blue, derusted and painted. Also the big brake swap pieces from Blue also derusted and painted. Or at least one side. This happened over a few days of slow days at work. And some off the clock work. Swapped in the rear into Tex with the brake lines and new parking brake cables. Also the last time the car ever had the original engine in it. And the final picture is the engine removed from the car! That intake mounted engine hoist plate was a life saver and it didn't require me to remove the hood to get the engine out!
How do you run into hood clearance issues with valve covers?
