View Post
The MEG (My 86 LTD Crown Victoria Coupe)
Sounds mean. Leave it as is. Just secure the h pipe so it does not put stress on the headers.~David~
Nice AC compressor bracket
Sounds good. Shame the trans went TU that quick. What cam is in there? Not nearly as lumpy as the one on my Towncar. I like it.86 Lincoln Town Car (Galactica).
XE270HR.
Dave, it's obnoxious. It will be getting a full exhaust after it's got a good transmission.
As for a transmission, it will be getting the AOD that came out of Vicky. Before that though, I will be pulling apart the original trans to see what happened. Fluid does not smell burnt. It was shifting weirdly when I got the car. So maybe it was on it's way out? I'll be sure to update. As a precaution, I'm probably gonna install the performance direct driveshaft so that isn't a factor to fail after this is installed.
Now I wanna put a good exhaust on my car so my engine can breath and race you.
Good and healthy sounding without being too much.
Now all you need a white 86 wagon and you’ll have a triple play.1990 Country Squire - under restoration
Nice!!!
For the clock and radio, did you swap out the tint for red ones? Looks good.
Edit:
My friends '83 tudor's transmission did the same thing. Acted a little weird and then lost 3rd and OD. Fluid isn't burnt and pressure is good when we tested it. 1 & 2 and R shift fine without any issues. Still hasn't gotten it fixed though so no idea what caused it.Last edited by slack; 06-16-2019, 04:07 AM.
usually losing 3+4 is direct clutch or direct drum related. Thats the "other" typical fail method on the AOD if the OD band isn't the problem.86 Lincoln Town Car (Galactica).
Edit:
Originally posted by gadget73 View Postusually losing 3+4 is direct clutch or direct drum related. Thats the "other" typical fail method on the AOD if the OD band isn't the problem.
