On Saturday, I collected the axle and exhaust from Derek after a junkyard run. Thanks again for the floor space and hauling it back from the yard.
Yesterday, drained the rad flush/water mix. What came out was super gross, and since the rad was clean due to the 2.0 having been a clean engine inside and rad being new, that means the block was gross. Glad I flushed it.
After draining, I ran hose water (yeah, yeah, I know) through the block, as well as thoroughly in both directions through the rad and heater core until nothing but clear water ran out. Hooked it all back up, filled with a full jug of concentrate plus the balance in distilled water and that should be that (capacity looked like 6.8L, jug of concentrate 3.78). Installed correct lower rad hose at the time (application: 95 Ranger 2.3 due to extension pipe at bottom of water pump)
Meant to install the (correct, newly received) block heater but forgot. Draining and refilling again won't be the end of the world. Just sucks because I was right there already.
Installed a 94 accelerator cable. This fixed the geometry at the throttle, no more binding, no weird spacing issues. However I had to use spacers (for now, zipties) to take up slack at the pedal. I might use the newer year pedal if I determine that will take up the slack sans zipties. The pedals appear to mount in the exact same way, just with different arm curvature.
Truck put in some work hauling junkyard stuff as well as maybe 600lbs of computer stuff over the weekend. Pulls hard, even loaded down pretty well. Passing people in 5th without dropping a gear is something the 2.0 could never do in the time I had it.
Fuel economy was really good for the speed traveled. Not reporting numbers until I see how it behaves in more normal driving.
Previously outstanding concern still stands, worried about compression figures. Going to be retesting that soon though as engine was cold and cylinders were washed with gas at the time of the last test (which gave 130-140ish PSI)
![](https://farm2.staticflickr.com/1937/45341747001_f4629f556b.jpg)
![](https://farm2.staticflickr.com/1942/44618683874_08d8b3025e.jpg)
![](https://farm2.staticflickr.com/1904/43490015680_e5e6cbb858.jpg)
![](https://farm2.staticflickr.com/1922/43526283250_33e25cd8bf.jpg)
![](https://farm2.staticflickr.com/1918/45304956661_4d0dcea271.jpg)
