A minor update, as this has still been seeing periodic use (such as to pick up that '90 K-code rear end recently):
Following the brake work, there is an awful metallic rattle noise coming from the front end when going over minor bumps. This goes away when the brakes are applied even very gently. Seems I cleaned out the channels the pads and calipers fit into a little too well and now the pads are rattling around. Will need to figure out some sort of way to silence this. There are no anti-rattle clips, but a quick glance at RockAuto suggests there are supposed to be.
The cap/topper that is on the truck currently continues to be most of what I want. One of its shortcomings has been that I haven't had keys that fit its locks, and when I inspected the latches to see if I could pull them apart and maybe re-key them myself, it was too much of a corroded mess to get apart nicely. I browsed around on Amazon and eBay looking at similar hardware and bought this in April:
Which looked like it would do the job nicely.
Tonight, I installed them. This entailed:
And like that, I now have a locking cap. Obviously, someone could just break a window if they see something they want, so I continue to try to come up with some sort of tool and cargo concealing solution.
- Disassembling the existing latches to obtain the nuts and inside-facing handle pieces to be reused on the new latches
- Running a thread die down the square shaft of the new latches to match the threaded length of the old ones
- Thoroughly lubricating everything and assembling the new latches on the cap with the mixture of new and old parts
