Finally, I can stop spamming this subforum with new threads as I pull them out of My Rides:
This is my 1985 Ford Ranger, purchased with 123,768km in May 2015 for $600, which in retrospect was too much.
Summarized from the Ford Ranger Forum thread:
The second day owning it, the gas tank started leaking. Drained the tank into gas cans via the fuel line (truck was given to me with a full tank). Replaced fuel tank with new.
June through November 2015:
Drove it all through winter into 2016 when it was seasonally retired to drive my '91 Grand Marquis for the warm months.
In October 2016 a junkyard Ranger showed up with a TK4 transmission, which received a more durable and much more fun to use metal ball shift lever instead of the plastic one of the TK5. I swapped the shifter and the truck became a lot easier to drive, with shorter throw due to less slop.
As of today the toe is still out by a lot, so I don't put tires I care about a lot on this for dry weather and only run the winter tires when weather is appropriate. I still want to put a better alternator on it, I'm thinking one of the small 3Gs from a Tempo might work with some alterations for mounting.
Here are a bunch of pics:
Originally posted by kishy
View Post
- Replaced timing belt
- Flushed coolant with old rad (which had a seeping leak). After flushing out, replaced radiator/cap, hoses, thermostat, coolant.
- 100% new brakes and lines, both hard and soft, all around, except for the drums themselves
- new parking brake cables
- engine oil (first time in 7 years, but not past mileage interval yet), differential oil, trans gear oil (Redline MT-90)
- pulled out the axle shafts to verify bearing riding surface is good and replaced axle seals
- Air filter & fuel filter
- license plate lights (corroded wiring due to botched trailer connector install)
- new tail lamps (old were cracked)
- new shocks all around (crappy yellow Monroes)
- headlamps
- blower motor resistor
- New floor pans screwed in (yes, screwed)
- Added 12V sockets, as truck wasn't optioned with a lighter socket
- outer tie rod ends
- Carb removal and rebuild
- patched passenger cab corner (really half-assed)
- Received Ontario Safety Standards Certificate. Drove it to work that day.
- Checked compression, looked good at the time, haven't checked it since
- ran wiring for radio and installed one
- Installed newer Bronco II mirrors
- replaced ignition coil (new) and Duraspark II module with good used
- Converted all 11xx style bulb sockets to 31xx style bulb sockets
- Converted front side markers to signals which alternate with the actual turn signal (a la Panther Blinker Mod)
- plugs/wires/cap/rotor
- Changed trans output shaft seal and installed obnoxious lights, because truck
