Today was one of those progress without progress days.
I picked up bolts (plated, stainless couldn't be had locally) to take the place of the cat-to-manifold studs, and unfortunately hadn't banked on the extra gap the 90 TC manifolds introduce because of the tapered end (vs the stock manifold, which is flat), so the bolts for that side were too short. Great. They do fit the original manifold, of course, since that's where I got my bolt length from.
Looking at it and thinking about it, I think the original manifolds are going back on. With all new hardware it won't be the end of the world to take them out down the road if needed. Knowing myself, though, I probably will never actually do that...
I redirected my attention to the tailpipes, since it needs to be done, even if I'm working backwards.
I "made" a hanger for the driver side using a bent universal hanger, and since they're direct-fit tailpipes, the passenger side one fits with the factory hanger. I need to come up with something better for this but at least I've got the pipes over the axle, positioned correctly.
Likewise, I need to figure out a permanent solution for the hangers in front of the axle, but I'm thinking once the H is in place it might hold everything together and "just work" which would be cool. What needs to happen here will become clearer once the manifolds and cats are in place.
The pipes were quite low here, I've since adjusted that, and will make sure they're not too low when it's all together.
