Next to branch off from My Rides is my 1984 Town Car, which is my current DD and the car of mine the most of you are most familiar with I'd guess.
Acquired in May 2016 for $650 in barely running condition intended to be a plusher winter beater since my Ranger is punishment to spend much time in, but I like it too much to let the salt eat it now so I'm back where I started.
There are pic attachments in the below original post:
This car was a relative nightmare due to electrical gremlins. The evening of December 31 was the night I finally got it to what seems to be 100%, and other than fluid services and yesterday changing the battery and starter relay, I haven't had to work on it (knock on plastic wood).
In January 2017 I was in a fender bender (other driver at fault) which broke a turn signal, fender extension, and damaged the already poor paint on the passenger side fender.
I was not at fault, and insurance paid for the repair. In doing this I took advantage of the opportunity to do a Mark VI header panel swap I had been considering doing anyway and had all panels ahead of the A-pillars painted. This took quite some time to be completed due to delays with my insurance company but it got taken care of in the end, in April.
In the meantime, RockAuto featured this car in the February 2017 newsletter with the photo taken just prior to the crash posed in front of Fisher Body Plant 21.
The Mark VI swap is something I said I'd do a write-up on, but it's difficult because my implementation is a bit of a hack-job. Physically, it all bolts on no problem. The controls for the doors, on the other hand, are where I went a little rogue. I need to revisit how I did it and will most likely do a write-up once I fix the shortcomings of how I did it originally.
Also in April I did the 130A 3G alternator upgrade:
Alt vs alt:
Stock harness (85 LTD CV; 84 functional equivalent; LTC has extra wire for oil level)
Laid out left-to-right as it sits in the car
Altered harness (same as above, with alternator stuff removed, except the wire to the light in the cluster)
Fuse
Tada!
Obligatory posing shots:
And something from today:
Originally posted by kishy
View Post
View Post
View Post
Alt vs alt:
Fuse
Tada!
