I believe I've seen that grey ghost once before as well. It was for sale at that point, somewhere near me. Had to be the car as it's got the same spot of pink/red by the tail light.
Have you done a compression check on this car? I can't remember reading if you did/am too lazy to go back and read. Checking fuel infectors for effectiveness would be great, just not sure how. I've asked about it in my F-150's page. No dice on this forum or the truck specific forum. Hesitant to go to the tubes of you. What do you have your timing set at? Because if compression is good, either try using higher octane gas or back off the timing. That's what I'd do.
(The last part, too lazy for compression unless things are basically beating me over the head to check it)
