No progress on the car tonight, but I did spend the evening prepping the garage to move forward - putting tools back, cleaning up boxes and packaging from parts, sort of "resetting" the space.
I believe if I had to take the car as it sits today, it would go well enough. That being said, the outstanding wishlist is as follows, in no specific order:
- Dash cam. I have a Thinkware F200 hanging around that will go in this.
- Tail pipes. I believe they will cure the exhaust drone, so I'm going to try to make them happen. That being said, I'll survive if not.
- Fan clutch. I have no reason to believe it's not working well enough (especially without air conditioning), but there is visible oil leakage on it, and I have a new one on-hand.
- Air conditioning. I have the parts, oil, and refrigerant, so it's within reach, but not worth burning an evening until other things are done first.
- Install transmission cooler. I have one on-hand.
- Install the control wires for the turn signal sequencers, so that they do not sequence when braking. It's just two wires from the column/cluster area back to the trunk.
- Quick wash/detail, including interior.
- Get my hands on a full-size spare of appropriate size. The other set of HPPs has tires that are substantially larger, so I'd rather not do those. 98-02 brakes so I can't do a 15, as far as I know. I have multiple donuts but no full size spare matching the current size.
- Take another look at the drum brake adjustment because it's not clear that it's right.
- Flush the brake fluid out with the fancy ATE DOT4, which I have on-hand. I don't think I have performance pads for the 98-02 setup so I guess I'm just rocking what I have. It stops very well, but fade is what I'm concerned about.
- Poke around with the EGR stuff
- Snug up the steering gear a little bit. Feel is great but it does have a dead zone that I'd like to reduce.
- Go through the ignition bits and see if any items I have on the shelf can make an improvement with anything, such as the minor misfire at high load low RPM. Fairly sure I have plugs, wires, and a rotor, but not a cap.
- Identify a clunk I heard tonight from the front end, which I suspect (sort of recognizing the tone and conditions that cause it) it may be a lower control arm with insufficiently torqued bolts so it rocked backwards with braking.
- It has been very tempting to change the transmission fluid and with the new fluid, add the same Lucas stuff I did to the wagon, but I can't afford the setback of what happens to my timeline if the Lucas additive causes undesired effects on this car. It worked wonders in the right direction on the wagon, but this transmission's behavioural concerns are quite different than that one. I've done the fluid in this car twice in the past. I will try to be gentler on this one than I was on the wagon, but it will probably still see a fair bit of manual 1 to hold second on uphills where third isn't gaining speed.
- Fluid leak status is looking good for trip readiness:
- Engine oil: appears to be no leakage.
- Coolant: jury is still out. If any is being lost, it's very little.
- Transmission fluid: appears to be no leakage.
- Axle oil: appears to be no leakage.
