kishy's 1985 Country Squire
    Well....one is on the way for my Vic.
      Last night I swapped the passenger front spring for one of my ex-91 factory front springs. The springs look to be the same diameter, same number of coils, and same free height. Left and right sides are sitting the same, and I am now completely confident that the spring is properly seated in its pocket. I really don't know what the deal is with it. Maybe the extra weight of a wagon behind the rear axle has a natural leverage effect and they just want to go high in the front?
      I'll probably cut a coil on each side. Speedway springs (I have a set) ride like garbage. I want this to be a squishy couch and stock spring rate, just with less spring, is probably the best way to do that.
      Separating the upper balljoints is so much less dramatic with the 92+ stuff. No ruined boots.
      | Junkyards
        Let us know how the spring cutting goes. My '98 sits entirely too high, it has 100% stock springs up front with stock air ride in the back, yet it seems to sit higher than every other '98-'02 GMQ. I don't know if its because its an HPP and the springs are firmer and therefore haven't sagged while every other '98-'02 has, or what its deal is. When I got it, it had that "bodies in the trunk" look, I thought maybe the RAS was tired, but inspection showed the air springs look perfect (impressive for 21 years old) and the height sensor had never been touched best as I could tell. I ended up adjusting it to its full maximum height setting and that made it at least level front to rear but its now just too tall overall. I need to deal with the original ball joints soon, so the thought of cutting a bit off the front springs while I have it apart has been on my mind. Beauty of having RAS is that I can adjust the rear ride height in about 5 minutes by loosening a single bolt and moving the sensor, and it will always be at that height no matter what.
        -Steve
          Well, cutting the springs definitely achieved what I was going for. It now sits much more similar to my 91, maybe a bit lower. I removed one complete coil and that was probably a slight bit too much, but the car now rides quite a bit nicer and is raked in the correct direction rather than the hideous one. Side note: whoever decided it looked cool to make pickups be lower in the back should really re-evaluate their life choices.
          This was also the perfect amount of spring removal to make reassembly not require a spring compressor, or other methodologies...just put it in by hand.
          Death of the Aquavision:
          Spring fun:
          Compare vs:
          (no hood, however, the hood did not push the front down any more once installed)
          Also, the AMP light keeps coming on. Sometimes right away, sometimes after a period of driving. Charging voltage is healthy at 13.7-14.5 (keeping in mind the Ford manual says the regulator holds it at 14), lights do not pulse/flicker, radio and chime have no interference noise coming through. Swapped the regulator and found no change. Very odd.
          | Junkyards
            Originally posted by BigMerc96 View Post
            My '98 sits entirely too high, it has 100% stock springs up front with stock air ride in the back, yet it seems to sit higher than every other '98-'02 GMQ. I don't know if its because its an HPP and the springs are firmer and therefore haven't sagged while every other '98-'02 has, or what its deal is...
            Welcome to the party. My '97 is similar where any other Aero I've seen is usually an inch or three lower than my car. I've only ever swapped out my rear springs for stock replacements because mine did start sagging back there, but the nose never has.
            @Kishy: The ride height looks good. Your rake is similar to my wagon with the cargo coils in the rear, though I think you're a bit lower in the nose. Doesn't look bad though, and is a considerable improvement over the monster truck lift those old springs were giving you. Hopefully those springs were added sometime later and that car didn't leave the factory riding around stupidly high like that when new.
            Regarding the AMP light: Possibly a intermittent connection issue between the regulator and the cluster, or is even charging steady with the light on? Never played around with a vehicle equipped with an external regulator, but having looked at wiring diagrams I've noted the similarities to internally regulated Ford setups.
            My Cars:
              honestly to me it looks low in the back
                Really surprised how much that one coil affected the height. Was not expecting that at all.
                See, to me, the rear looks perfect, the front was too high, and the front is now too low. Not bothering to look up what's correct here, really doesn't matter that much in the end. I don't like that I've lost crashworthiness (bumper underride now that the front is lower) but it was not just a cosmetic issue. The front upper bump stops were completely destroyed by the control arms smushing them into the frame, just sitting at normal ride height. This is seemingly an issue that was introduced by the 92-94 arms. There was virtually no suspension extension available for going over bumps...plenty of compression if you hit the bump real hard, but no room to extend further. Now that I've given it oodles of travel it rides very smooth.
                I had played around with the positioning of the stock camber/caster adjustments to see if that would fix it, and it did not. Pushing them out to maximum positive camber corrected it the most it was able to, and even then, there was still nowhere for the arm go to go let the suspension come down any more. And of course positive camber is goofy. It will "look" even lower once it gets aligned, which should be interesting.
                The alternator is charging even when the light is on.
                | Junkyards
                  unplug the regulator and see if the light is still on. if it is, you've got a short somewhere in that circuit. I think that bulb is also supposed to be bypassed by a resistor. If thats open you might be getting enough draw to light the thing. Is it full bright or partial? I'd expect not quite full if its the resistor.
                    I don'don't recall which car it was but if the light is missing the alternative won't excite.
                      I don't recall which car it was but if the light is missing the alternator won't excite.
                      Common arrangement. The light is on the ignition switched power circuit for the regulator. With the key on, 12v passes thru the bulb in the cluster and powers part of the regulator, when the alternator starts charging it sends voltage back across that same wire, now the bulb has 12v on both sides of it and it therefore no longer lights. The light should be on any time the cluster has power and the alternator's output is lower than the battery's voltage such as with the key on and engine off. Most clusters (but not all, especially older ones) have a resistor in them along with the bulb so that the circuit remains complete and alternator should still charge if the bulb is burned out/missing.
                      -Steve
                        I had the cluster out & had to drive it... oops!
                          I'm leaning towards a short, but it's weird. Shut the car off, start it again, the light sometimes reverses whatever its previous status was. No real consistency.
                          It is at full brightness when it is on. It has been seen flashing (I say that to differentiate it from flickering - on/off, at random, but at either 0 or 100% brightness, nothing in between).
                          Drove it to Detroit yesterday, junkyarded with a friend in it. Car did well. The extreme toe-in became very apparent while driving it at higher speeds so I toed it out a bit and that helped a great deal. It will get aligned soon, I just have to decide if I'm happy with the springs first. The ride is right, but I'm thinking of maybe trying half a coil off my old 91 springs and seeing how it sits on those. Once it's aligned, there is no more spring swapping. Spring height changes alignment.
                          On the bright side, of course, this confirms that anyone who wants the height of the Speedway springs, but wants to preserve ride quality and not spend any money, can just cut a coil...I need to find someone to offload those Speedway springs to. I will never install them in another vehicle. I don't hate myself enough to do that again.
                          Another benefit to how it is now: I don't have to unseize the headlight adjusters. The sky-high headlights are now at the right height.
                          | Junkyards
                            Okay, so the rake is much more apparent in that picture than the above ones.
                            Are you shooting for factory ride height or raked stance? I'm only asking since if you dropped the rear, that wouldn't look too bad for leveling, otherwise it looks like the nose needs to come up ~1-2" to get it leveled up there.
                            Otherwise, throw some meaty tires back there and make it look like it means business.
                            My Cars:
                              So...I don't know what I'm aiming for.
                              Refer to this:
                              Observe the height of the brightwork along the rocker panel, relative to the turbine centre caps, then compare this same reference point on the wagon. Useless trivia, those are in fact the same turbines that just went on the wagon, but with the Ford caps.
                              The springs that were in that car at the time that photo was taken, were later removed.
                              I then put those springs into this wagon and it did not change the height, it was still as pictured with the crazy high front end, and destroying the upper bump stops.
                              Then I cut one coil each from the springs that came in the wagon, and we got where I am now.
                              I cannot account for any reason why this car should be so seemingly light up front. No AC and no smog pump, but the weight of those items just isn't enough to do it. Plus the 91 has an aluminum hood and the wagon has a steel one. The wagon just does not want to settle on stock height springs, it wants to stay stupid tall. Until I cut a coil, of course
                              That's why I'm thinking maybe cut half a coil off the old 91 springs, and maybe that'll get me about right. I do not want to bring the rear of the wagon down and I do not want it fully level. Very mild rake is probably a reasonable goal.
                              | Junkyards
                                Back in the early 90's I had a straight 6, 4spd '81 Capri. I wanted it to handle like my Stang so I put 5.0 swaybars on it, then decided to put 5.0 Convertible springs on it. It sat way too high. Rule of thumb @ that time was cutting 1 coil would lower a 5 oh car 1". My thought process was that a 6 must be lighter, I'll remove 1.5 coils. So I spent quality time with my wife and a hack saw, several packs of blades and a front springs in a 5 gal bucket. It sat so low in the front that the K member was about an inch and a half off the ground. Turns out weight of the 3.3 L is similar to that of the 5.0. Needless to say, I acquired another set and only took off 1 coil LOL.
