View Post
But agreed, it isn't full of grossness so that helps.
Originally posted by 87gtVIC
View Post
View Post
View Post
View Post
Tonight, torqued down the intake manifold. No going back. Here's hoping the gaskets stayed aligned correctly. The tabs on the head gaskets weren't doing their job holding them up so they could have shifted slightly. Hoping not.
Drilled a hole in the trans pan and drained that. A drain plug will go where I drilled.
Pulled the filter. Drained the torque converter.
Fluid is super dark, super gross. Not much of a smell to it, but it's definitely past its prime. I was the first person in there in the car's life (dipstick plug in pan).
Fluid refill will wait until closer to being able to run the engine.
