kishy's 1985 Country Squire
    I dig the triangle indicators. Why I like F-Series trucks from '87-'91 more. The last American vehicle I'm aware of which used foot actuated high beams and had indicators not within the gauge area or close to each other.
      As much as I want to see the wagon finished (and eventually see it in person) it makes sense to me to focus on getting the ranger done before winter.
      Vic
        Interior A pillar moldings do have to go on/come off without a dash pad installed.
          The 85 mph speedo was actually a federally mandated thing here for years. I think it stopped in 90 or 91. The idea was that if your speedometer wouldn't read past 85, you wouldn't try and go faster.
            What a stupid idea eh?
            Fireturd's goes to 120 and optional was a 140 unit. I like the 120 better as beyond that, I'm not going to be looking down anyway and it's easier to discern lower speeds. But, it's an '89. Bet automakers had to pay a tax or something to have them read beyond 85.
              maybe 1989 was the end of it, but it was somewhere in that time period. 89 Mark VII had an 85 speedo, 90+ had 120 and the clusters will interchange.
                Could have been. But I'm fairly certain that starting in '87 the Formulas and Trans Ams got 120mph clusters and then the 140 was optional. I've never seen an '87 with anything but the 120mph cluster, even the V6 ones. Literature shows there is an '85 available and even a basic cluster with just a speedo and idiot lights in place of gages.
                  The first wagon bolt of 2019 has been turned!
                  Started work on the front end rebuild. This was not strictly necessary, however the brake system needed to be 100% redone with all new everything, so it seemed like a smarter investment to cover the front end parts at the same time. The "might-as-wells" catalyze each other and you end up with it making a lot more sense to just do the brake swap. In this case, 95-97 to accommodate my 15" cop car steelies.
                  Ball joints and tie rod ends are Moog Problem Solver. Upper control arms are junkyard 92-94 arms, with new Moog rubber bushings. Inner and outer tie rod ends are Moog Problem Solver with Quick Steer adjusting sleeves. Bump stops are being reused. Lower control arm along with its bushings is being reused. Sway bar end link is McQuay-Norris under the ProSteer brand (the one for the other side will be Mevotech, also under the ProSteer brand).
                  Yes, only one side done (and even then, incomplete) in an afternoon...I'd be really bad at doing this professionally.
                  | Junkyards
                    The spring try and kill you?
                      Yes, actually...it put up a much better fight than my 91 did.
                      The only reason I took it out was to evaluate the condition of the lower arm bushings. They are in usable shape so it went back together. I don't think I'm going to take the spring out on the other side. Those things contain all sorts of pent up hate.
                      I was half tempted to put my Speedway springs in because of how much easier it goes together on them, except I completely hated how my 91 rode on them, and won't fall into that trap again.
                      | Junkyards
                        I truly hate messing with the springs on these. I changed mine 3 times to end up back with stock replacement springs. No more of that crap.
                          Sinus infection has gone away. Work slowly resuming.
                          Knocked off the passenger side knuckle and upper control arm. Forgot to put the jack under the LCA when I cut through the sway bar link...it's a good thing the arms have a good lip on them to hold the spring or I'd probably have taken some damage from that lapse in judgment.
                          Put the new shock in but found one of the lower holes is stripped, par for the course. Went rooting through my collection of bolts and found something that should work but it's quite a bit bigger. Surgery to install that will be another day.
                          I'm feeling a lot better about the condition of the frame now that I've taken a wire brush to some of the extra scaly spots. It truly is just surface rust. This frame is as solid as they come, it's just ugly. A thorough powerwash, forced air dry, and then oil bath will need to be done.
                          I also found what appears to be some sort of fungus growing on the intake manifold. Kinda neat in a really weird way. Pics to come when I remember to take one. It's a green jelly that I initially mistook for antifreeze but I'm pretty sure it's an organic growth, bearing in mind how much grossness existed under the hood of this when I dragged it home.
                          | Junkyards
                            Ooo biology. Did you taste it?
                              No...no I did not lol. Although if it is Nostoc, which it appears to maybe be, it seems it wouldn't do any harm. It's clinging to vertical walls on the intake manifold so I don't see how it could be antifreeze; that would be pooling rather than clinging.
                              Passenger side is assembled with new lower ball joint, junkyard knuckle, new upper ball joint, junkyard upper arm with new bushings, new shock, new sway bar link. Tie rods for both sides are on-hand but not yet installed.
                              Hubs, calipers, rotors to come later. Brake plumbing is coming soon; as a refresher, that will include a new booster (old is already removed), newer style master cylinder without frame mounted dual system valve, and new hard lines all around using mostly metric flare nuts with bubble flares.
                              I noticed that in order to re-add AC to this car I will need to get the bracket that goes below the compressor, where the idler mounts, as that bracket was removed when P.O. de-smogged the car. It is my intent to make the AC work on this.
                              I also had a lightbulb moment. I earlier described the car as sounding "like a tractor" for the first minute (or less) of runtime. I think it's the same thing that happened to my Lincoln when I pulled the air pump and found the check valves don't really work. The TAB/TAD is still connected and as such it's venting the cylinder head air pipe to atmosphere until the solenoid is triggered by the computer. So when it's finally time to run this baby again, I've got something to look for. Still a fair ways out from that though. Need a gas tank and lines and stuff.
                              | Junkyards
                                I love seeing the front end conversion from the original setup to the later Panther stuff.
                                When you take that setup in for an alignment, do they align it as a typical Box or an early Aero? Are any of your other cars running with that setup, and if so, how is the brake feel compared to the stock stuff?
                                My Cars:
