kishy's 1985 Country Squire
    make sure you clean up the axle extremely well. I tried two sets of those on my car, neither sealed so it ended up with new axles. The shafts were rusty on mine at the point where the new seal sat though and there just wasn't a usable seal surface. Hopefully yours are in better shape.
      Shiny lenses. Very nice.
        I didn't look too closely at the bearings but these seem to have a seal on both the inside and outside, as the bearing is intended to be greased and not lubed by the gear oil (I think). So hopefully as long as the inner seal seals, and the outer one kinda seals, it all works OK...
        But that being said I consider it temporary anyway until good axle shafts wander my way. I'll clean up the axle shafts a bit and see what I'm left with.
        Yes...far too nice for the car, but I just couldn't deal with the thought that one light would be brighter than the other if one was NOS and one was factory installed and sun baked since 1979.
        Didn't really have to break the bank either, the pair were $103 US shipped. More than I'd like to have paid but not really unfair at all.
        | Junkyards
          Fabbed up some adapters to use the 89+ speakers in the 88- cars (specifically to put 89 speakers in the wagon). I keep finding 89s with good speakers but 89 has the newer connector.
          I took the little connector bit (essentially a piece of circuit board with two fat traces forming the terminals) off my dead speakers and attached 89(+) pigtails to them, turning them into adapters. Good solution for keeping things reversible (and also predictable, as in knowing what to expect when revisiting the topic in the future).
          Factory dash speakers are in, autolamp sensor is good, so it's almost time to put the dash pad in...almost...but I know if I do that, the ATC vacuum sensor thing will turn out to be bad. Date on it is weird. The year appears to be "907". Clearly some sort of oopsie when stamping the date onto the part.
          Since the window motors all work now, the rear locks work, and the front doors now have good speakers and correct pigtails soldered in, it's almost time to close the doors up. Window channel is absolutely screwed in the back doors which causes the glass to go down funny, but I'm not investing good brand new window channel in this car at this time. I'll revisit that in the future. Need to hunt for an adequate adhesive or tape solution to attach the junkyard-scavenged plastic moisture barriers to the doors to protect the new door cards. This stuff is fairly unimportant to the overall progress of the car but it's symbolic in a sense. The car will really look a lot less trashy with a decent interior.
          Carpet can go in and seats be bolted down once the fairly small rust hole on the passenger side is taken care of. It's just the pre-existing hole normally occupied by a rubber body plug from the factory, but widened out a bit by rust making that plug no longer fit. Repair will not be extravagant, just functional.
          | Junkyards
            Solder sucker!
              And what a sucker! (I so want a desoldering station... I currently have a similar solder sucker and wick to do the job.)
                Yeah, I'm a fan of the solder sucker vs the desoldering braid. That's a cheap eBay one from China and it does just fine.
                If I were bulk-desoldering (parting out/recycling stuff) or doing it as part of a regular job I'd probably go for a fancy desoldering station (plus a hot air rework setup plus other goodies) but since it's all just hobby-tier work done on an occasional basis, I get along OK.
                This is my iron...I've really grown to like it: https://www.soldering.com.tw/solderi...ion/SL-20.html
                | Junkyards
                  I bought a Hakko 808 desoldering gun years ago and have not yet been sorry for it.
                    I pretty much have the same setup as kishy... wick for cleanup/lead conditioning/small stuff, solder sucker for typical through hole stuff, and a Weller PES51 iron. I also have that butane Weller for outside jobs so I don't have to jack with an extension cord. I use a MAP torch for lugs.
                      Wow nice to see you save this wagon, this thread is amazing ! Good luck !
                      1987 Colony Park LS wagon
                      1988 Grand marquis LS sedan
                        Did a couple things.
                        Put the A-pillar trim back in. Broke one. It appears these are intended to go in before the dashboard. There's a good one in the P72 that showed up in Detroit recently but I may not bother...the break is down almost out of sight.
                        Tested the ATC temp sensor as per my post the other day. It was not capable of providing heat whatsoever. Replaced with known-good; the one I removed will be kept for future repair experimentation.
                        Laid the new junkyard dash pad in. What an awesome find that was...it's nearly perfect. This car will not feel nearly as trashed inside as it did when I got it.
                        Used heatshrink tubing on some disintegrating insulation on the instrument cluster pigtail. Put the cluster in; photo is from the 'bulb check' with key in Start. The symmetry of these clusters is kind of nice. Note the '79 speedometer face has giant triangle turn signals, not shaped arrows. Also note I put in the '79 fuel gauge which has the actual word "fuel" instead of the symbol used in later years.
                        Dash reassembly will come once the Tripminder works again. All of the buttons are unresponsive. Suspect corroded contact pads.
                        Just need to sort out the power locks (2/5 work - ordered some new ones) and window channels (unusably bad, windows slip out of track alignment due to missing sections down in the doors), then I can put the doors together with their 'new' junkyard moisture barriers and door cards. Lock actuators are coming from Auto Parts Warehouse and are their house brand (brand name is just "Replacement"). I suspect they're probably a white-box Dorman part. I think even the Motorcraft example is by them. If it's not Dorman then it's probably Wells.
                        Then, some minor floor work for a small hole on the passenger side and the carpet can go in. Interior will be a nice thing to cross off the to-do list.
                        | Junkyards
                          was/is 100kph the national speed limit up there at some point? Just wondering what the orange line is about. Speedos here usually had "55" in a circle or bold when that was the national limit.
                            It's a weird sort of thing. I don't believe we ever had a "national speed limit" the same way you did, but at the time that 55 was the standard in USA, 100 was the highest speed (I'm aware of) anywhere in Canada. Even today the majority are 100 (62), but there are some higher examples.
                            The Town Car has the same thing, yellow line beginning at 100, as does my '83. However, the '91 cluster (original Mercury or the P72 that's in it now) had no such markings.
                            | Junkyards
                              I like the fact the KMH clusters go past 85 MPH. Hell, if I could find a Mercury one for not insane money, I’d consider just dealing with imperial readout being secondary. Only downside is recorded mileage would all be kilometers, but my drivetrain isn’t original and the current mileage far exceeds mechanical limits.
                              My Cars:
                                Yeah, that always seemed strange to me. Seemed like a reasonable amount of cost could have been saved by having the speedos be identical mechanically and in calibration, but just changing the printing for each market. Probably a good reason why they didn't do that. Regardless, we know in stock form the cars can easily exceed the 85MPH speedo so I would guess there was a political reason for it at the time with which I'm just not familiar.
                                Ordered some parts tonight, mostly for the Ranger. Need to progress on the engine swap. I want as many ducks in a row as possible before turning the first bolt on that project. Original goal was finish wagon then start Ranger, but I believe I won't make it happen by winter if I don't start the Ranger stuff pretty much immediately. One of the biggest hangups is actually the fuel sender. I got my hands on an EFI one that fits my existing tank but the gauge sender is all screwed up. As far as engine swap problems go, this is nothing, so it's a good thing it's my biggest problem so far...I'll bump the Ranger's thread when it's time to talk more about it.
                                | Junkyards
