After having some less-crap-but-still-not-roadworthy tires put on the wagon turbines, so I'd have something to store and roll it around the driveway on, I put two of those on the rear axle today. Keeping the donuts up front for now because it's easier to steer not running that way. Power assist is also not working when running, might just be because it's empty, hoping that's the case.
I beat the drums pretty hard with a BFH, and got the passenger side one off. I turned the adjuster in a bunch so it'll come off easy in the future. The driver side, which is the side that had the parking brake seized, did not want to come off. The shoes are right against the drum. I put this side in the air and ran the engine, trans in gear, other side chocked, to try to wear the shoes down a bit. No go. Drum got super super hot, but I still couldn't get it to slide off over the shoes. I'll have to try to wind in the adjuster through the access hold on the backing plate.
Rolled it into the garage, since the below-freezing weather is probably not ideal for windshield urethane application, which I'm hoping to do this weekend. Taped up the old windshield and lifted it out onto the roof.
Pulled the cluster out and rebuilt it with the new speedometer. While testing bulbs, I burned a trace on the flexible circuit sheet. Repaired it, surprisingly it went OK, I was expecting soldering to melt the thing pretty aggressively.
There is a difference between the older and newer clusters...not sure what the change over year is. The hole for the high beam indicator is smaller on the older speedometer face, and the little icon is too big on the newer cluster insert for it. I opted to put it in backwards so the symbol isn't visible with the high beams are off since it doesn't line up properly.
I'm going to have to watch for an orange-needle early year car to pop up to take its fuel gauge from, or find an orange paint that's close. The mismatched needle colour is no fun.
