Undercover Boss
    Undercover Boss
    I'm more interested in that what, '77 T-bird?
      Xxx[ATTACH=CONFIG]48057[/ATTACH]
        Took it out he boss for a drive today and the throttle stuck. It backed off after hitting shift point and rpm limiter just before IWAS GOING TO SHUT THE KEY OFF. The ball and socket connection had rust on it and was sticking at full throttle only at the TB. Popped it off the ball and sprayed some krill oil in the socket snapped it back on no more sticking.
        The bird is for sale
          Deetz on this T-bird. Pics too.
            anyone ever wounder or take a guess whats under the cover
                Looks like the profile of a '79-'93 Mustang.
                  Looks like Mad Max Interceptor. Wishful thinking, I know it's a Fox body.
                    it a 91 GT 5 speed tremac, 3.73 rear i think, possibly an E cam. I am the 3rd owner 80K ran a fax on it
ID:	1282966Click image for larger version
ID:	1282967Click image for larger version
ID:	1282968Click image for larger version
                      there is a Mad Max Interceptor bit to it like 10lbs of boost
                        plans are to sell off the tires and wheels and install some 17" x 9 wheels with some fatter tires. sell off the the vortec set up. probably use my cobra maf and ecm set up used on creamy, install an intake with egr. go with 3.27 gears. sell off the ratech suspension. only issues with interior is ash tray common already have the parts to repair it. Door panel map pockets have been ripped off or removed for some reason will order new panels next. Clean up engine compartment. change factory heads might use my ported E7s. maybe go back to a stock cam. Thinking about that 32.9 MPG build i did in creamy. Wounder if the fox body which supposedly only needs 7 hp to cruse at 65 or so might do better. I have done 28 in my 84 fox gt carbed. cant stand the radio in it one that is for hooking up to a smart phone. not easy to use traveling down the road. was surprised the cargo cover was still intact as my 84 at a 6 years old came apart.
                        Sold off the flow crap 40s and installed some dynomax super turbo muffs no more droning boost also hit 10lbs of boost insanely quicker
                          wrong thread.....
                            here is the wheel 17 x 9 FR500 replicas all around. rear tires 275 x 40 x 17s fronts possibly 245 x 40 x 17 or 245 x 45 x 17. as i only purchased one tire and one wheel will trial fit the rear set up on the front to check for clearances
                              Did you sell the old wheels?
