View Post
2000 Crown Victoria New Project
1992 Mercury Grand Marquis.
Upgrades: Big Brake Upgrade, digital dash, Custom ignition Switch system, sequential tail lights, Teflon Fuel lines, LED interior lights, rear end rebuild with limited slip.
Future upgrades: 5.0 swap, 4r70w swap, aluminum driveshaft.
Originally posted by 87gtVIC View PostWheels look nice with your paint job.
Anytime you have to redo something at least it should take less time.1992 Mercury Grand Marquis.
Originally posted by sly View PostI looked at the bends of the pipes when I did the heater core in the 2000... 6 inch core in my wife's car. Nailed it first try.1992 Mercury Grand Marquis.
Originally posted by pivichot View PostIt wasn't that bad to be honest. Just that my hands could not remove the damn blend door actuator. That last bolt was a pain on the firewall.
As far as the 2 sized heater cores, I don't think they ever actually used anything other than the 6" one on any Panther built between '90-'04. There was that mid-year change in '89, and supposedly another mid-year change in '05, otherwise they were all the same. Why so many places list 2 options, IDK.-Steve
