My brother got a gold GM LS with ride & handling package (meh, air ride converted to coil) for my nephew's first car. Put a new alternator in it and some 80k mile tires which my nephew proceeded to beat the piss out of and shred due to not rotating (which was free) and a bad ball joint. Either pooched a rim or the spare with it being loose (not sure which yet).
I am trading the beater '90 TC for it, got the upper right ball joint taken care of, and it goes in next week for new Cooper tires/alignment/end links/& sway bar bushings.
The only thing is it uses oil. Blue smoke on startup, don't know how much it uses how fast (I asked if it was 1qt/wk & nephew said "Yeah, it used an entire 5 quarts between oil changes!"
You don't change the oil every five weeks, kid). Will get some pictures in the next week or two probably and post more about the problems it has, but I wanted to see what everybody thinks might be the problem causing it to use oil & if it would be worth fixing, changing the motor later, or just run it until it dies. Thanks.
