My 1987 Mercury Colony Park
    Still haven't looked at the cluster. Need to, but it seems if the car is driven regularly, the issue doesn't occur. Doesn't make a heck of a lot of sense. Seems the illumination/backfeed wackiness only happens after it sits for several days and clears up after the car is driven a bit.
    Only thing I've done is swap LEDs into the rest of the back of the car. Swapped the tag lights for warm white LEDs several months prior.
    Used the "fancy" built-in resistor type LEDs on the tail/brake/turn bulbs so I could keep the original style 323 flasher working along with the speed control. No problems with that. Even with the built in resistors, it seems some draw must be reduced, as the dash illumination doesn't flicker a touch the way it used to with the original bulbs when I'd hit the brakes. I also used "standard" LED for the reverse light since the originals were considerably dull. Overall I'm pleased with the additional brightness from all the bulbs.
    My Cars:
      I did LED reverse lights in the Cont trying to get some more out of it when the reverse light switch was jacked and dropping a bunch of voltage. It helped but even now with a good switch thats not losing 3 volts they aren't very bright. I should pull those and see if the reflective coating in the housing even still exists.
        Yeah... LED reverse lights on my 93 don't do well (but those are small to begin with) and the LEDs on the Expedition are like rear headlights. Nice and bright. basically 921/912 vs 3156. 3156 has much more headroom to work with.
          That looks really good.
            not sure what they are on the Conti, its whatever bulb has the same base as an 1156, but the glass part is like half the size of an 1156. It got 1156 replacement LED though since they fit. Just cheap crap tho which is likely not helping.
              Got a little trip coming up soon. Figured I'd address a few things that really have needed done for a while, and some new stuff that's gonna get done tomorrow.
              Had originally noticed a slight pulsation when braking, but it was more of an on/off catch feeling, less of the warped rotor sensation. Found the RR drum was kinda damp inside.
              Yay, leaky wheel cylinder. Dunno how old it is and how many miles are on it, but its getting replaced regardless. Going to go ahead and do both sides and install new brake shoes as well since these have been exposed for who knows how long at this point. I'll also take care lubricating the backing plate points and cleaning/lubing the self adjuster once I get it pulled apart. I'll bleed the whole system with some of the Bosch ESI 6 fluid I have that's supposed to cover DOT 3, 4, and 5.1.
              Took my drums up to O'Reilly and cut 'em. I've had a long standing agreement with the current manager to be able to still use the lathe after left about three years ago. Today not a single person I recognized was in there and the assistant manager was out, so there was a substitute from another store who had to actually verify if I could use the machine after he told me "they don't cut drums/rotors anymore." Honestly a bit shocked knowing that now and the fact that the lathe otherwise is used for storage. That was one of my more "enjoyable" things to do then and honestly worked out pretty good for customers on certain rotors cost wise.
              After all that fun, I did reinstall the drums and wheels just so the car wasn't on stands the rest of the day. Addressed a handful of inoperative lock actuators. Passenger RF and LR just managed to get the electrical connector loose. Reconnected, works good again. Addressed the tailgate one with a good used one from a '89 since that one legitimately went missing some time ago with no explanation. Found the fold down safety latch arm had also detached and fallen into the tailgate.
              This arm is depressed by the window when its rolled down which then releases the safety latch so you can flip the tailgate down instead of opening it as door if you prefer. The plastic clip on the arm had given up. I'd also had the clip on the lock cylinder rod break and prevent me from operating the lock/window system as well. Luckily, the Dorman 75450​ pack of door rod clips had all the needed bits so I was able to fix the lock cylinder and the window safety rod.
              In case anyone has to deal with that rod falling out, there's a hole to the right of the fixed rod it inserts into. The rod goes behind the window regulator assembly and otherwise kinda dangles in free space once its fitted.
              Tomorrow is brake repairs, and Wednesday I'll do a interior/exterior cleaning and final check. Should be all good to go for the weekend.
              My Cars:
                finding places to turn rotors and drums is like pulling teeth. Before the machine shop at the Napa closed down they told me it was going to be a month before they could get to it. GTFO. Shame my lathe won't swing over a 10" diameter, I'd just do it myself. Its not a brake lathe but on some level a lathe is a lathe. I really don't want to buy a brake lathe for the rare occasions I need one. besides the space it would consume, I would end up becoming "the brake rotor guy" in the area and I really have no interest in that.
                  Wow, a month? Yeah, miss me with that one. I'm in a similar place where it just doesn't make sense having a brake lathe for such infrequent use. It's a cool idea, but totally impractical. Plus, I'd hate to consider having to buy replacement bits. I don't recall them being particularly cheap, or at least they weren't at the store.
                  Perhaps I should order a set of 11" drums and machine them, put some protective coating on them and throw them in a corner instead for the future, should I ever manage to actually wear the existing Ford stamped ones out. I've seen a lot of new cast drums that were probably more akin to a oval than a circle. Had a shop that used to insist we'd cut them before sending them out, and I saw absolutely why once it started to cut.
                  Anyway, the car!
                  Tossed together my discount brake job on both sides. Had a box of closeout RockAuto shoes I'd ordered forever ago, an ancient Parts Master branded set that was probably the most cohesive marriage of NAFTA era production: mounting plates made in Canada, friction linings from the USA, and all riveted together in Mexico. New wheel cylinders from O'Reilly (best Chinese specials) and recycled brake hardware.
                  Set the star wheel adjusters, fitted the drums, and nothing would bleed. Like, a little fluid came out of the RR cylinder and then nothing. Couldn't get anything out of the LR cylinder. I've bled brakes on various cars of various years, so I was a bit surprised that I had a very firm pedal and virtually no travel. Finally opted to try it with the car running, and then it was game on as I had full pedal stroke again. Purged all the air and bled all the corners with some Bosch ESI6 fluid I've had on hand, which is supposed to cover and exceed DOT 3, 4, and 5.1 applications.
                  Got the car into the street and did a few reverse stops to get the self adjusters set and the pedal leveled out real nice. Brakes feel much more confident now with fresh fluid and no leaks.
                  Tomorrow will be a wash and interior cleaning. Should be good to go for the weekend.
                  My Cars:
                    This. It's why the drums on my truck have ruts from the shoes. I'm not making an appointment with the only shop that still turns the things. Well, I did once. Naturally, the guy was out sick that day.
                      So I know I've mentioned somewhere around here I've had issues with the aftermarket speedometer cable I got. Binding issue causing the speedometer to lock up and other strange behavior. Anyway, I got a bit frustrated after it locked up again recently and decided to revisit that problem with a junkyard speedometer cable from a '89 LTD CV.
                      I had a bear of a time getting the cable core to come out of the replacement VSS I installed (a Standard Ignition brand one) prior with the new cable. Then it dawned on me there was a mark on that replacement cable that showed it barely was engaging the cable and forcing the extra distance up into the speedometer head. The OE cable wouldn't fit at all. Apparently the aftermarket VSS square hole for the cable end to go into was too small! I'm a little shocked I got it installed in the first place, but the extra cable length getting jammed up against the head would explain it since it should seat well into that hole with some movement room.
                      I grabbed a VSS out of a '89 Town Car, replaced the seals from the newer VSS and tossed that into the car. Huh, it all fit properly with no issue. I've likely misplaced some of my frustration with the cable, when I should have been looking at the sensor. Food for thought if anyone needs one, probably best if you can catch a Motorcraft unit or good condition used one.
                      My Cars:
                        Aftermarket parts are really ticking me off lately! Sounds like I am not the only one.
                          nah its an epidemic of trash. I've increasingly been NOS parts shopping and hoarding because at least I feel those parts have a reasonable chance of working even if they are 40 years old and dusty.
                            Between all the other vehicles, I really have not been driving the '87 since January. Annoyingly, the speedometer chatter came back, and after doing a little diagnosis, it's the head causing the chatter. Pulled it and applied some light oil to the bearing and shaft area, and it seems easier to spin now. Hopefully that's just it in need of lubrication, because I'd really rather not smoke this particular speedometer head.
                            Also seems the battery is finally going flat, so I guess it'll get a fresh battery post cluster reinstall this week.
                            I definitely want to get this one back up and in fighting shape since it's the only car here with working A/C at the moment. The LTD and F-150 are in line for getting their air fixed, but I'm just not there yet.
                            My Cars:
                              Finally bothered putting everything back together today. Only been dragging my feet for ages. Speedometer head was lubricated, and all illumination bulbs were replaced from the 2825 (W5W) bulbs to warm LED because I found the 2825 bulbs were running too hot. Arguably I thought there was a chance those bulbs would be okay while improving brightness, but not at the expense of how much heat they truly generated.
                              Haven't met a cooked color filter, but that was indeed from the bulb. I had to swap three of the filters due to heat related damage.
                              After fitting the speedometer back in, I fiddled with the ride height sensor rod adjustment since I noticed the compressor hadn't been cycling normally to keep the car trimmed out. Got that set to keep the air shocks at a reasonable nominal inflation point to prevent the bladders from running low/empty under normal driving circumstances. A fresh battery was also installed since the old one was getting weak. Had to switch to a 24R instead of the 64 type since 64s have become hard to find around here.
                              After verifying everything was good, finally took the wagon down to the "dollar wash" to clean off all the dust and crud from sitting around for the last several months.
                              Still runs like a top. No issues on the drive to and from the car wash, so I'll count that as a completed fix.
                              My Cars:
                                As someone with both the Ford and Merc instrument clusters, which one do you prefer? I've always liked the look of the Mercury but haven't actually had any seat time with one.
