My 1987 Mercury Colony Park
    Ive seen a few of them still around in the junkyards but they disintegrated when I went to flex them. I did want to get it.
    I have been using a locking style since forever. I also do not want a cap rubbing against the paint. If a tethered option was available combined with a neato holder for the removed gas cap while filling up I would be compelled. I just place gas cap on top up gas pump during fill ups.
      So I grabbed a few more things from that '87 at the junkyard. I thought I could get an un-seized door lock actuator from a rear door out, but I couldn't figure out that setup way up there in the door. I did notice that car seemed to be riding the line between '87 and '88 parts. I took it's weather barrier, and it was a nicer plastic E8 branded one. Car was a 07/87 car. Might explain why it has the later style air vents that seems more in line with the '88-'89 cars.
      Anyway, I've started swapping the air vents over to replace my floppy early style ones. The later ones look nicer and do feel more sturdy compare to early ones. I'll update with some pictures later.
      I also grabbed the ECU from that car, simply because I figured it wouldn't hurt to have a spare. Any magic I should be aware about these SEFI ECUs? This one is branded with a catch code "DU" and a series "SFI-SD1". P/N E7SF-12A650-U1A.
      My Cars:
        Good question about the ECM. I've always wondered if one year had a better tune compared to the others or if they're all the same. I've pondered the same about GM vehicles.
          Only real difference (functionally speaking) in the ECUs for speed density cars 86-91 is the 88-91 have cruise built in and not in a separate module.
            yeah, basically that. Related to that, the late ones need a VSS input, the early ones do not. No VSS input on a late ECM makes the EGR valve open at stupid times and you'll get a nasty off-idle hesitation.
              Here's a dumb question: Lets say a capacitor has begun to fail on a board, but not fully failed, is it possible that the drive cycle memory may be affected? I only ask since I've noticed if the car sits for several hours, when fired up it runs like it just had the battery reconnected. It has to figure out its idle every time. Sometimes it'll stumble on the initial take off, then never do it again until it sits for a while. I've noticed it usually would run better throughout the day if several short stops were made where the engine was off for less than 30 minutes, then restarted.
              I figure it's equipped with the original computer. I doubt the capacitors were designed with 32 years of operation in mind, especially in a hot and humid climate, based on what I've read. I'm going to inspect the ones from the salvage yard, and possible change those out. I'd like to see how the factory ECU looks inside.
              My Cars:
                More likely the ECM may be having an issue driving the IAC. But there's only one large capacitor in the ECM (at least the one for the 88 I had) so it wouldn't be that hard to check after taking the lid off the ECM.
                As for how it looks inside... Here's the pics of when mine released the magic smoke. The cap puked and lit it up.
                  Oh wow, that's some shit stain!
                  Did the car still run? Was that ECM salvageable/repairable?
                    Nope. Had to replace it. The PCB burned all the way through. All of that blackened area was complete toast.
                      I wrestled the ECU out of the '87. It really didn't want to come out.
                      This one is stamped RM, has the gasket number blacked out, and someone wrote a number on the other side. I suspect all that points to this ECU having been a remanned unit. Carries otherwise factory Ford stampings and warranty sticker, so no idea if it's a Ford remanned unit.
                      FWIW, the capacitor towards the rear of the board is leaking out on one of the legs.
                      I haven't been able to open up the LTD one yet since I used a socket that was a bit worn and nicked one of the screw heads on the upper portion, and my good socket doesn't get all the way down to the base, so it just slips on the nicked portion. The rest came out fine. I want to inspect that one for any additional revision markings inside.
                      My Cars:
                        The ECM doesn't actually use the caps for memory purposes, it has a constant +12v feed from the battery for that job. To my knowledge, the caps are mostly used as internal power supply filters after the internal regulators drop the voltage to whatever it needs to be at. The green leaky bit will eat the board if left long enough. Mine was that way when I opened it for the Quarterhorse install. Wasn't acting funny and I won't tell you it acts different with new caps but at least I'm not worried about the board rotting or the cap shorting and blowing something up. Looks like thats how Sly's fucked out. Usually they go out with a whimper, but sometimes its a bang.
                          I had that problem with one of the screws on the burnt one. I used some "beefy" needle nose pliers and got it started that way. If you have some needle vice grips... that may work better.
                            Huh. So if there are different part numbers and revision codes, then something must actually be different inside them. Whether its the programming, or if Ford just got 1 chip from a different supplier, who knows at this point... Its pretty well known that the later cars use several different strategies on mostly all the same hardware, sometimes several strategies within the same year/make/model. Like how model year 2000 cars have a pretty lame factory programming compared to a '99 even though nothing really changed mechanically and the PCM hardware is the same. Ford seemed to almost alternate the programming, every other year they'd be good, '96 is okay, '97 is aggressive in comparison, '98 is okay, '99 is very aggressive, and '00 is lame. The one thing the "good" years have in common is a tendency to ping under load, I've had that in my '97, but not in my '98 until I installed the '99 P71 PCM which does run noticeably different and feels more responsive like my '97...but pings...like my '97.
                            Also now y'all got me wanting to open up the '97, '98, and '99 PCMs to check for aging caps. Honestly never even thought about that before, but they do live in a harsh environment and they are 20+ years old.
                            -Steve
                              Well I got the LTD one open. This thing looks super nice inside compared to the CP one. I’ll post up some pics later, but noticeable differences was the addition of a Texas Instruments chip in place of one I couldn’t identify, and the disappearance of a Motorola chip.
                              The capacitors on this one are good, but will be replaced for serviceability sake. Is it okay to replace a polarized capacitor with a non polarized unit or should I just stick to the original style polarized unit?
                              @BigMerc: I’ve got a spare ‘97 ECU from a police car laying about. I’ll take a look inside and see if it’s suffering from any issues. It was known working a few weeks ago.
                              My Cars:
                                it is, but NP caps in those values will be larger and you might run into fitment issues. No real reason to not use the original type unless you're changing them to film.
