View Post
My 1987 Mercury Colony Park
My Cars:
ford wiring from this time period isn't awesome. My Towncar and the Continental both had sections near connectors where it was bare for a couple of inches and crumbling for several more.86 Lincoln Town Car (Galactica).
The wiring in the Mad Marquis for the fuel pump, horn, and AC cutout relays was pretty bad before I did the aero relay swap. On the horn relay, the insulation from the "hot at all times" wires was shrunk back a full 1.5 inches. On the fuel pump and AC relays is was about 1 inch. I trimmed that back quite a bit.
I find Liquid electrical tape helpful in some cases. It comes in colors.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Decided to tackle the relay job today.
FWIW, the later style vacuum/relay combo pictured here does not really work on a modified early fender liner. The relay holder is too "deep" since the area is flat. No idea if the '90/'91s are any better, but the early side mount vacuum/relay combo is preferred.
Fuel pump relay wiring was the worst as far as insulation recession went. The yellow lead could be yanked straight out of the block.
Factory ground splice, IIRC. Whatever fabric based taped that was used crumbled off when I removed the wires from the harness. Re-wrapped with electrical tape.
All wiring exposed with relays hanging.
Updated relay holder installed with EEC diode. This was going to be a solder and heatshrink job, but the ancient (and cheap) iron called it quits after I did one lead. Since I had already cut the EEC relay 100% out, I was committed, so butt splices with heatshrink were used instead.
Stuff "tidied" away. The holder doesn't sit just right since it's a new style holder on an old style vacuum box. I'll see if I can find a side mount holder next time I'm at the yard so it'll sit nicely. At least it's latched into place.
I had to extend two leads out, one for the EEC connector from a leg on the fuel pump relay, and another for the A/C Diode lead from a leg on the A/C cut-out relay. Beyond that, I was able to shorten up most of the wires by about a foot and adjust the looming to fit.
Here's a note card of all the pinout/wire colors I used.
FWIW, the EEC relay wiring did not 100% match my service manual. The 12v+ Constant BK/O wire was just Black and the Ground BK/LG either originally was green and faded, or it was using black with light blue striping. All the other wires matched respectively.
My Cars:
your handwriting is entirely too legible for a working note card. My scrawl of notes when I'm putting stuff together may as well be in hieroglyphs.
Honestly that wiring is in better shape than many are. Nothing there makes me go "aha" though. I wonder if one of the relays was failing mechanically. If the return spring breaks, you'll get stuff randomly engaging if it gets moved around.86 Lincoln Town Car (Galactica).
I guess that is why the later harnesses use a similar splice, but embedded in marine type heat shrink. The stuff with the glue in it that oozes out and seals things when its heated. I had to cut a few of those out when I did the cornering lamp retrofit on my '96, I couldn't find in-tact '95-'97 GMQ side marker harnesses that had cornering lights so I modified ones from a '94 instead (basically deleted the extra bulb and wiring for the turn signals, but also integrated the "blinker mod" since it was cut up anyway). I cut one of those factory splices apart out of curiosity and the splice its self looked pretty much the same as that one, but it was in heat shrink rather than wrapped in tape. FWIW, my splices were done similarly, soldered and marine heat shrink, because IMO that is the only way to do splices under the hood if you expect them to last.-Steve
the later harnesses were sealed up better. The tape wrapped blob splices were typical through the 80s at least. The connectors are also not sealed other than with whatever terminal grease that may have been packed in there.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postyour handwriting is entirely too legible for a working note card. My scrawl of notes when I'm putting stuff together may as well be in hieroglyphs...1985 LTD Crown Victoria - SOLD
Here's a dumb thing I've never checked for:
Tethered gas cap. Saw it on the junkyard '87 and took it. I've had a replacement Stant unit since I got it, and it clearly had been around for a while. Just a bit curious how frequently those pop up, or if anyone else has one and I've just been the sucker dealing with a basic cap.
My Cars:
The tethers commonly break. The 90s models had a single cord to the top center of the cap rather than the "hinge" thing that the 80s cars got. Those seem to hold up better, and they fit boxes fine. The one on my car is from a mid 90s Escort. The original was broken when I got the car.86 Lincoln Town Car (Galactica).
The one like you installed is what the Mad Marquis came with. The strap never broke. I did have to replace it though because the cap failed. The single plastic string on the 93 though... that one broke... and then the cap failed. So it's got a new one as well. Though that was several years ago now.
Interesting, my '89 has the single string type (broken string). I wonder if it's not original if the 80s ones usually came with that strap set up.
