Would the 98-02 fans work
Buyer's Remorse (AKA "Hideous") - Giraffe's 1990 Grand Marquis LS
Originally posted by knucklehead0202 View PostThis is why i'm having a fierce debate with myself over fan installation. I have the brand-new clutch that came off the wrecked car, with fan, and the one currently on the car is fairly fresh. Pretty sure i can get my stock shroud to work with the big radiator i have, but do i hassle with it? Also already purchased big dual derale fan that moves 4000cfm. Either way i suppose it's taking a chance...1985 LTD Crown Victoria - SOLD
Originally posted by DerekTheGreat View PostI got a nice one at the yard over the weekend. Was intended for Ashley's truck but uhh, looks like I was right in thinking it wouldn't work for it. Her truck is that weird spin off style or what have you. I dunno, now we have a spare! .......Vic
Originally posted by VicCrownVic View PostJack up the price and sell it to that guy who said "it looks like the same thing."1985 LTD Crown Victoria - SOLD
Originally posted by DerekTheGreat View PostEh, I think it'll work for box/v8 stuff and I could probably use it on my Townie. That or we could take it back this Sunday & exchange it for one that'll fit. Seems to require special tools to remove her type of fan clutch properly. Anyone know the type I'm talking about? They attach to the water pump via one large nut in the center. Trouble seems to be holding the pulley still, I think that's what the special tool is for. I'd rather not buy/rent one but will if I must...Vic
Originally posted by Elias View PostWould the 98-02 fans work
My 93 is using the later version of the 98-02 fans (single coil fan with resistor for low speed). Works just like the contour fan would. The radiator is the same mounts as the boxes, so it should work fine. I mounted it to a F150 dual core radiator, but the real trick is using the whale relays as well because 70A relays for a 50A fused line for 40A peak power draw and 27A running on high. I would avoid the dual coil fan as if the relays latch and both turn on, the fan coil fries. They are easy to ID as the oval in-line 3 wire conncetor is on the motor itself instead of on a round 3-wire connector on the shroud.
If I were to pull these parts from a junkyard car, what all would I need to pull to include the relays/harness?—John
1985 Ford F-150 XLT Lariat
Originally posted by knucklehead0202 View PostThis would be ideal. My auto-electric buddy says that's what i should go with if possible, otherwise he doesn't trust e-fans. I need to dig out my big radiator and see if these derale's will fit. If not i'll be examining other options.
Originally posted by Giraffe View PostIf I were to pull these parts from a junkyard car, what all would I need to pull to include the relays/harness?
I did manage to find a few original Motorcraft fan clutches available on eBay and snagged one for $40. Not too shabby. Hopefully it'll last until I switch over to electric.
In other eBay news, I also got my hands on a NOS driver's door latch. I found the part number, searched it, and there just happened to be one available listed for $13. That'll get hidden away until the car gets a new paint job or whatever. Or maybe not. It'll probably work wonders for the way the driver's door closes.—John
So I happened across a local guy who is liquidating his entire (extensive) collection of early-Ford parts. Among the old parts, there was a mostly complete 5.0 out of a Fox Mustang. It included the long block, accessories, flywheel, lower intake, and 19 lb. injectors. It also happened to come with a set of unknown brand 1.6:1 roller rockers. All this for the low price of $150.
Craigslist ad is here if anyone is interested in any of the parts left over (which include a set of factory Fox headers). He has an AOD that he said I could have, but I need to identify what kind of AOD it is before I think about taking it.
Tom, I seem to recall you saying that you were wanting to acquire a set of Fox 5.0 accessory brackets? Let me know if you would like these. I have all the brackets and pulleys from this engine. I have no use for them.
It's difficult to see what kind of shape the bores are in. Some crosshatch is visible, but it's faint. Wouldn't be surprised if it needs to be bored. E7 part number on the pistons, so it's probably not the forged internals.
Plan is to have this engine rebuilt, new internals if necessary, and eventually drop it in the Mercury. Its engine will then come out and will eventually be rebuilt for eventual use in the '66 coupe.
—John
Originally posted by Grand Marquis GT View PostNice!!
Any yes, i would like those leftover accessory parts.
I was actually wrong about the pistons. I did some searching and they are the forged pieces. They switched to hypereutectic in 1993. Hopefully I can resuse everything and get by with a re-ring. The goal is for this refresh to be as inexpensive as possible. Otherwise it will never get done.—John
