Finally! I found this car locally at a junk dealer and snatched it up for $950. It's a little rough, but should clean up nicely.
The good
The bad
Minor things
That's about all I can think of right now. There is so much oil residue everywhere that it just reeks when it's running. Can't wait to clean it up. I have an OBD I code reader, so I'll also be pulling codes first chance I get (I'm sure there are few).
Pictures!
Thanks for looking! Plans for this car in the short term will be upkeep and returning it to a factory-new driving condition. It's nice to be back in a Panther!
The good
- It runs!
- TV grommet is there and the transmission shifts nice and smooth with no slips I can feel. I plan to have it flushed/serviced when I get a chance.
- The power mirrors and driver seat work!
- It's an original Oklahoma/Texas car with zero rust.
The bad
- It sounds like it has the dreaded knock. It didn't seem like it was low on oil pressure (never got a light, and it does work), but it does seem to be there.
- Every corner has a different brand tire and it's a bit wobbly going down the road. The ball joints have grease fittings, so hopefully they've been changed before. I'll likely be replacing most if not all the suspension/steering components in the future.
- It's been sitting for a while and will need a new battery. One of the previous owners also wired a dash-mounted start switch that jumps the solenoid posts. I ordered a new Motorcraft solenoid and will be swapping that out to see if it'll crank off the key.
- None of the windows roll up or down. Both passenger and the rear driver windows sound like the plastic pieces are just chewed up. That should be an easy fix. The driver door window, on the other hand, makes no sound or movement with the switch. Hoping that's just a bad switch. I ordered an EVTM off eBay and will hopefully be tackling any wiring issues I run into.
- The door locks also make no sound or movement on either switch.
Minor things
- The engine bay is ridiculously dirty from oil leaks (valve covers) and evidence that the previous owners lived on a dirt road. The engine bay is covered and there is also a patina of dirt embedded in all of the interior cloth. This isn't really that bad, but it looks terrible and I'll be a bit nervous about it until I give it a thorough cleaning.
- The dome light is rusted/pitted and has a missing lens.
- The latch tabs on all the ashtray doors are broken; they're all stuck open.
- The tabs on the HVAC sliders are broken; it's difficult to adjust temperature or set the controls. Probably will just eBay another.
- Radio doesn't work.
- Retractable antenna works, but has a bend in it which causes it to bind near the fully retracted position.
- Cigarette lighter doesn't work.
- The passenger c-pillar interior covering is delaminated.
- The passenger vanity mirror lid is missing.
- The grille is held on with a combination of string/wire. Anyone know how it attaches? I'd like to get that properly fixed.
Pictures!
