I bought the ignition module, have to wait until the weekend to install it though :C
I bought a box!
Hey guys, I have no brakes. I push down on the pedal, my foot goes straight to the floor. I don't think I could stop from anything higher than 20 miles an hour. The reservoir is full. Master cylinder bite the dust? The BRAKE dummy light comes on, but that reservoir has brake fluid in it.
Originally posted by killgore View Post...Its not leaking a ton of fluid anywhere...1985 LTD Crown Victoria - SOLD
TFI module replaced, haven't had it on a long enough drive to see if that was the cause or not.
My Dad came down to help me with my master cylinder, he helped me by a second new master cylinder (stripped the first one out). Got to figure out some way to repair/replace the hard line. String of bad luck all at once.
Lucky to be close to headquarters.
Two times my Vic lost brakes: While getting an inspection at my dads friends shop. Just backed onto the dyno to do the emissions testing (this is YEARS back when this still needed to be done to 95 and older vehicles in New York) and BURST. Pedal to the floor. Hard line under the drivers door blew. Second time was in my driveway! I think it was after installing the HO upper intake and bored out egr spacer and throttle body. A hard line either from the master to the proportioning valve or from the proportioning valve to one of the front calipers gave out. Of course the fittings seized in the prop. valve and out came the torch. The torch proceeded to MELT the brake switch. OOPS. and I needed to purchase a new prop valve. Just nice being near tools both times this happened.~David~
So just a little report. A new TFI module and fuel filter solved all of my stumbling issues, my low idle and my cruise control issues. Other than that, just hit my first oil change. I also have dropped my muffler at some point in my adventures, so duals it will be. Just a little update mid month, may get a zero to 60 video soon. Thanks for all of your troubleshooting helps/tips guys!
Nice, glad to hear things are working better.
Dropped the muffler at some point... unknowingly?Vic
Stumbling issues? When and under what conditions?
My car is sporting the original dizzy & TFI module. It sometimes stumbles when you go to give it gas off idle, like a carb'd car that doesn't have it's accelerator pump set up right.1985 LTD Crown Victoria - SOLD
