Mean Mr. Mustard
    Mean Mr. Mustard
    '87 5 spd 50 HO Mustang.....so named after an '87 project 'Stang owned by Steve Collison from Cars Illustrated, SuperStock & Drag Illustrated, Muscle Mustangs and others as well as the Beatles song and the fact that it is Medium Yellow.
    It was garaged not long after my eldest Son was born. We are getting it back in the road for him to learn to drive. Gotta start 'em right!
    Where's the pictures... And the burnouts..?
    Originally posted by SVT98t
      I miss my old 87 LX 5.0/T5, it was a beast.
      Mine had a B&M shifter with stops, and I loved going through the gears with that. I'd install a shifter with stops, helps you not break the transmission too. Made the T5 feel solid.
      Also I felt the stock HO cam was weak in the low end, didn't come alive until about 2000 rpm. I don't know how guys here run it in their heavy cars with an AOD and high axle ratio. Maybe with lower gears than the stock 2.73's it'd be ok, but I'd rather install a better cam and be able to have longer gears. My car had BBK headers and o/r H-pipe, helped but still lacked the low end torque it could've had. I wish I had kept it long enough to install GT40 heads/intake along with a cam to really wake it up.
        The HO stick is lame at low rpm. Needs gear to make one useful. Oddly enough, I got some low end torque out of mine with that SystemMax lower. The Mark VII is all the weight of a Vic with the same low stall converter and 3.27 gears. I wasn't expecting anything down low with that intake, but it definitely gave me some.
          Lower numerical number is a high ratio, high numerical number is a low gear ratio.
          Sounds stupid and is against logic, but it's how it works.
          HO cams aren't good for power, they just give these boxes a wee bit more hustle, for cheap.
            It has had various shifters in it, currently has a short stick Hurst. Stock H/C/I, it does have stock headers and a 65mm throttle body. It does currently have 2.73s. We are currently installing a 2.5 inch Pypes Violator catback. I think this should be copious for the current situation, AKA Im learning to drive in it
            Metal head, guitar player and all around nice guy!
              Originally posted by tom-kat View Post
              it has had various shifters in it, currently has a short stick hurst. Stock h/c/i, it does have stock headers and a 65mm throttle body. It does currently have 2.73s. We are currently installing a 2.5 inch pypes violator catback. I think this should be copious for the current situation, aka im learning to drive in it
              is this jims son?
              Jim, is this your offspring?
                Originally posted by Bobcat View Post
                is this jims son?
                Yes, scary isn't it...
                  somewhat and very.
                    Let's hope he can keep up the precious care towards car tires that his father shows!
                      And you let him on here with us nutters?
                        He better have some care & concern, I put brand new tires on it (the old ones were bald for some reason).
                          Should've gotten him used ones. Rookie move!
                            *laughs maniacally*
                            We are probably going to finish the exhaust tonight.
                              Mean Mr. Mustard, cool Beatles tune.
